FURUTECH NCF BOOSTER-BRACE Dampening Support for Power Connectors 1 Socket
4.5 / 5
By buying this product you get 34 loyalty points
Reference : 14417
179,00 €tax incl.
149,17 € tax excl.
Shipping date: 30-09-2026.
NCF Booster-Brace
The NCF Booster-Brace by Furutech fits power distributors as well as wall power outlets in order to increase stability. It is designed for power cables with massive conductors. It is meant for user willing to achieve every possible optimization regarding the power supply of any audio equipment.
NCF Structure
The booster Brace is made in a hybrid NCF structure. This material has been specifically developed by Furutech and includes a crystalline material chosen for its ability to eliminate static charges and its efficient thermal dissipatiopn. This material also includes nano particles of carbon and ceramics which ultimately provide piezoelectric damping as well as resonance absorption. Nano Crystal² Formula is an unique solution for the mechanical and electrical damping of power connectors.
Anti-vibration grooves suppresses surface vibration whereas deeper vibrations are limited thanks to an inner air chamber which uses air pression to increase dampening capabilities.
This accessory is carefully protected by an anodized aluminum enclosure that will respect the esthetics of any listening room dedicated to very advanced audio systems.
Please note, the form-factor of the support meets the characteristics of the Furutech / IEC connectors. Be sure to check the dimensions of your cords / connectors if you do not follow this recommendation.
MaterialNCF
Anodized aluminum casing
DimensionsWidth 54.3 mm
Length 64.8 mm
Height 38.5mm
Internal diameter40 mm
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorN/A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
2 reviews
A recommander sur des systemes à bonne resolution
Produit tres efficace (comme tous ceux de la gamme Furutech). Attention cependant au placement. En premiere approche je l'avais plaqué sur la prise murale avec des effets difficiles a cerner.
Je l'ai ensuite installé à l'entrée du mon filtre secteur Gigawatt et là, superbe! Vient accentuer les effets du NCF Clear Line.
This review has been posted for FURUTECH NCF BOOSTER-BRACE Dampening Support for Power Connectors 1 Socket
NCF always delivers
Another Furutech product up to spec. The brace seems to be the cheapest (all things considered) way to NCF-ise your power cable!
