Livraison rapide, produit au top, mes enceintes fonctionnent encore mieux, le son est plus détaillé, je recommande.
Enceintes : BW 703S2
By buying this product you get 22 loyalty points
![[GRADE S] IBASSO DX240 Digital Audio Player DAP DAC ES9038Po Balanced Bluetooth 5.0 WiFi 32bit 768kHz DSD512 MQA Black](https://www.audiophonics.fr/53668-thumb_default/-grade-s-ibasso-dx240-digital-audio-player-dap-dac-es9038po-balanced-bluetooth-50-wifi-32bit-768khz-dsd512-mqa-black.jpg)
 ![[GRADE A] AUNE S9C PRO DAC 2x ES9068AS Discreet Headphone Amplifier 5W Bluetooth 32bit 768kHz DSD512 MQA Back](https://www.audiophonics.fr/64487-thumb_default/aune-s9c-pro-dac-2x-es9068as-discreet-headphone-amplifier-5w-bluetooth-32bit-768khz-dsd512-mqa-back.jpg)
 These "jumpers" or "shunts" are used to connect the two channels of a two-wire terminal block.
The cable used is the Silver-plated ViaBlue SC-4
These cables are made in germany
ViaBlue ™ T6S connectors, 24 carats are used for better contact.
Length 10 cm
The length given relates to the cable without connectors
Included Qty: Set x4
| Length (m) | 0.1 |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | Spade |
| Conductors Plating (Cable) | Silver |
| Average votes  5.0 / 5  3 reviews | Why write products reviews ?  You can share your feelings about products and help other people by sharing your experience |
Samuel L.
Samuel L.
michel l.
