AUDIOPHONICS WIRE Speaker Cable 5m (Pair)
This speaker cable is assembled by us in the Audiophonics workshops. The choice of materials has been carefully considered and every detail and finish has been checked to offer you a high-quality cable that remains affordable. It is composed of a MOGAMI 3103 cable with OFC copper conductors and gold-plated Viborg banana plugs.
Reference : 21387
169,90 €tax incl.
141,58 € tax excl.
Audiophonics Wire Speaker Cable Mogami 3103 Viborg Banana Plugs OFC Copper 2x 4mm² 5m (Pair)
Photo du câble HP audiophonics wire
This speaker cable has been developed for music lovers seeking optimal quality without loss and great neutrality across the entire bandwidth for superior musicality above all else.
Audiophonics Wire: Mogami 3103
The Mogami 3103 is a high-quality speaker cable designed to allow your audio devices and speakers to deliver their full potential. Each conductor, with a cross-section of 4mm² (11AWG), is made from Mogami Neglex OFC copper in a configuration designed to offer transparency and sound precision.
Audiophonics WIRE : MOGAMI 3103
Audiophonics WIRE : Bananes VIBORG
Audiophonics Wire: Bananes Viborg
These Viborg banana plugs feature high-quality design. The contacts are made of a gold-plated copper alloy, ensuring good conductivity and durability. The body is made of aluminum for greater durability.
Product typeHP cable
ConnectorsViborg banana plugs
Length5m
MOGAMI 3103 Specifications
Conductors number2
Conductors materialOFC copper
Conductors section4mm² (12AWG)
Conductors insulation diameterØ4.5mm
Insulation materialPVC
External diameterØ12mm
External sheath materialPVC flexible
Weight / 100m20kg
DC resistance0.005Ω/m
Inductance @ 20°C 1kHz0.6µH/m
Capacitance @ 20°C100Hz: 106pF/m
1kHz: 93pF/m
10kHz: 83pF/m
50kHz: 76pF/m
100kHz: 74pF/m
Max. voltage500V DC (15s)
Working temperature min / max-20°C / +70°C
Specification of Viborg banana plugs
Contact materialCopper alloy
Contact platingGold
Body materialAluminium
Maximum cable diameterØ8.5mm
Max conductor diameterØ4.5mm
Mounting typeTo screw
Dimensions41.5 x 8.5mm
PackageSold by pair
Length (m)5.0
ShieldingNo
Section (mm²)4.00
ConnectorBanana
Excellent câble hp Mogami 3103 de 2x5 m tout monté
Je viens de recevoir votre jeu de 2 câbles Mogami 3103, avec les fiches bananes fixées.
J'ai tout de suite été étonné par sa grande qualité sonore.
Ils relient un ampli Accuphase E-4000 à une paire d'enceintes Mofi Source Point V10 Master Edition.
La clarté ressentie et la dynamique du message sonore sont vraiment superbes.
Les câbles Mogami sont de grande qualité : j'utilise des câbles 2534 ou 2549 en rca ou bien xlr pour relier le lecteur cd Accuphase Dp 450 ou le Smsl PL 200 à l'amplificateur E-4000..avec la même satisfaction.
Le 3103 est à conseiller à tous les audiophiles.
Merci encore à Audiophonics pour ce montage et cet envoi à bon prix.
This review has been posted for AUDIOPHONICS WIRE Speaker Cable Mogami 3103 Viborg Banana Plugs OFC Copper 2x 4mm² 5m (Pair)
This speaker cable is assembled by us in the Audiophonics workshops. The choice of materials has been carefully considered and every detail and...
