Audiophonics Phono DIN to RCA cable
This Audiophonics phono cable is an interconnect cable that will adapt perfectly to your turntable/armature.
KEY FEATURES:
  • 4 OFC copper conductors
  • OFC copper wire
  • 5-pin DIN connector, OFC and gold-plated
  • 2x gold-plated RCA connectors
Reference : 18507
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 10-06-2025.
AUDIOPHONICS Phono Cable
 DIN 5 Pin to 2 RCA + Ground Wire 1.5m
AUDIOPHONICS Phono Cable DIN 5 Pin to 2 RCA + Ground Wire 1.5m
This Audiophonics phono cable is an interconnect cable that will adapt perfectly to your turntable/armature. This phono cable is made from quality materials. It consists of Sommercable SC-Peacock MKII modulation cable with 4 OFC copper conductors, each with a cross-section of 0.22mm², for excellent signal conductivity. A 0.5mm² OFC copper wire with FEP dielectric insulation and a gold-plated Dayton audio spade complete the grounding system. The conductors are specially designed for analog applications, and the cable is shielded to reject EMI/RFI interference. A braided sheath covers the whole assembly to effectively protect the cable against mechanical wear, tearing, twisting and the effects of prolonged exposure to light.
On the connector side, there's a 5-pin ND05 DIN connector from Viborg. The ND05 features PTFE insulation with pure copper contacts and triple plating including OFC copper, silver and 24K" gold. Two good-quality Neutrik NF2CB2 RCA connectors with gold-plated contacts and spring-loaded ground are also present.
Product typePhono cable
Conductors materialOFC Copper
Connectors1x DIN 5-pin female Viborg ND05
2x RCA Neutrik NF2CB2
1x Dayton audio spade
ShieldingOFC copper spiral sheath
InsulationFEP
PVC
Lenght1.5m
Weight175g
Package1x Audiophonics phono cable
Length (m)1.5
ShieldingYes
Section (mm²)0.22
ConnectorRCA
ConnectorDIN
This Audiophonics phono cable is an interconnect cable that will adapt perfectly to your turntable/armature. KEY FEATURES:...
