FURUTECH DSS 4.1 Speaker Cable OCC DUCC Copper Alpha Treatment 4.08mm² Ø19mm
This Furutech DSS4.1 speaker cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 / 0.18α-DUCC conductor. DUCC (Ultra Crystallized High Purity Copper) conductors are supplied and tested by Mitsubishi Materials Industries (the world's leading manufacturer of highest purity oxygen-free copper).
By buying this product you get 120 loyalty points
Reference : 15069
409,00 €tax incl.
340,83 € tax excl.
Shipping date: 29-09-2026.
Câble vendu au mètre
FURUTECH DSS 4.1
Speaker Cable Copper OCC DUCC Alpha Treatment 4.08mm² Ø19mm
This Furutech DSS4.1 speaker cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 / 0.18α-DUCC conductor. DUCC (Ultra Crystallized High Purity Copper) conductors are supplied and tested by Mitsubishi Materials Industries (the world's leading manufacturer of highest purity oxygen-free copper). This extremely pure material is processed with a technology meant to optimize crystal alignment while reducing crystal grain juxtapositions, resulting in an extremely efficient conductor.
The OCC conductors are the result of a further treatment with the Alpha Super Cryogenic and Demagnetizing treatment. They benefit from a straight alignment where its more massive "fibrous" crystals have an increased length in order to create the fewest crystalline junctions possible. The entire cable is insulated with an internal Fluoropolymer layer and an external polyethylene layer. Finally, a copper foil shielding with braided OFC copper makes it possible to reject interference and preserve the audio qualities of your devices as much as possible.
Furutech strongly recommends these specially designed splitters for this DSS 4.1 cable, available here: Splitter speaker cable DSS-4.1.
TypeSpeaker cable
Number of conductorsx2
Conductors89/0.18α-OCC
39/0.18α-OCC
62/0.13α-DUCC
IsolantFEP
P.E.
SheatPVC
ShieldingCopper foil, braided OFC, Paper
Diameter19.0mm
QuantitySold by the meter
Diameter (mm)19.0
Number of conductors2
Insulation materialPE
Insulation materialFEP
ShieldingYes
Section (mm²)4.00
Section (mm²)4.00
Ground / ShieldingYes
2 reviews
Excellent
Câbles chers, certes, mais qui apportent beaucoup à la restitution.
Encore en rodage, mais déjà beaucoup de sérénité dans le rendu sonore avec des timbres à la fois pleins et doux, particulièrement dans le haut du spectre.
Si, votre bourse vous le permet, n’hésitez pas.
Merci
This review has been posted for FURUTECH DSS 4.1 Speaker Cable OCC DUCC Copper Alpha Treatment 4.08mm² Ø19mm
Tout simplement génial
Je suis passé du furutech fs alpha au dss installation focal Diva Utopia, audio GD master 10 , he7 r2r ladder dac, auralic Ariès g2 , alim full dps , full furutech. Première heures tout de suite grosses amélioration mais c'est brouillon après 50h le dss commence à donner le meilleur de lui même. Pour faire simple c'est de la folie grave de dingue médium idem mais pour moi le top c'est les aigus d'une beautés les instruments sonne différemment il y a beaucoup plus de détails on monte le volume ça ne fait pas mal au oreilles on gagne en 3d les essais sur le net sont très élogieux et c'est vraiment mérité le seul IQ c'est le prix bien sûr et c'est vraiment dommage car si vous avez les moyens de vous l'offrir les yeux fermés. Pour moi c'est ridicule de s'acheter ce câble si l'on a pas Qobuz ou une source hires . Les spliteur en Alu 18 mn du site passe j'ai coupé la gaine tissu gaine thermo et on fait des économies. Bonne écoute cordialement
 (4)
This Furutech DSS4.1 speaker cable is designed with a 79 / 0.18α-OCC conductor, a 37 / 0.18α-DUCC conductor as well as a 42 /...
