SOMMERCABLE SC-ORBIT 225 MKII Speaker Cable OFC Copper 2x2.5mm²
4.5 / 5
Reference : 5086
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 08-09-2026.
SOMMER CABLE - SC-ORBIT 225 MKII
Hear pushing the grass ...
would be possible with SC-ORBIT. If you value a natural sound, dynamic and high fidelity, choose SC-ORBIT. The loudspeaker is at the end of the circuit, and the means of retransmission of the music are also of enormous importance. You already have a quality loudspeaker: the cable must also fulfill all requirements - and the result is remarkable! This is why we have created this superior quality in the elegant design, because the drivers are often visibly placed - and to facilitate the discreet installation we made them as flat as possible. The very short torsion of the strands of the core brings an improvement in theface conductive braids, ensuring a remarkable purity of reproduction of remarkable sounds. The two conductors being twisted in opposite directions, the cable always resumes its initial shape even after complicated entanglements.
ADVANTAGES:
  • Absolutely neutral transmission quality thanks to special twisted conductors.
  • High flexibility and easy winding thanks to the flexible PVC sheath comparable to rubber
  • Finish distinguished (transparent black sheath)
  • Low resistance values ​​due to special design
USE:
  • Connections for high-end hi-fi speaker systems
  • Indoor wiring for hi-fi speakers and PA systems
  • Fixed installations
  • Stereo connections for vehicles
Specifications:
Envelope, outside diameter PVC 10.2 x 4.8 mm
AWG13
Number of Conductors2 x 2.5 mm2
Copper strands per core 651 x 0.07 mm
Operating temperature min. -30 ° C
Operating temperature max. 70 ° C
Fire resistance per m 0.17 kWh
Weight per m83 g
Colorblack transparent
Type2 x 2.5 mm 2
Electrical Specifications:
Capacity metric cond./cond.<60 pF
Odometer Resistance, Conductor<7.8 Ohm
Resistance, insulation> 10 MOhm
Diameter (mm)4.8
Length (m)Sold by length
Number of conductors2
Insulation materialPVC
ShieldingNo
Section (mm²)2.5
Ground / ShieldingNo
11 reviews
Excellent câble
Sommercable est un fabricant sérieux qui fabrique des câbles d'excellente qualité pour différents usages. J'ai choisi SC-ORBIT 225 MKII pour mes enceintes DAVIS ACOUSTICS. Ce câble convient parfaitement pour mon équipement (chaine hifi DENON) et pour ma musique préférée (Classique). Le son généré sur l'ensemble du spectre est très homogène avec des graves "veloutés", des médiums parfaits et des aigus présents sans extravagance. Un câble conforme au descriptif qu'en fait SOMMERCABLE.
This review has been posted for SOMMERCABLE SC-ORBIT 225 MKII Speaker Cable OFC Copper 2x2.5mm²
Satisfaisant
C'est un câble de bonne facture. La qualité est bonne, facile à manier. Niveau qualité sonore, il est effectivement neutre, mais peut être pas totalement. Il se fait vraiment sur là-bas du registre, ce qui lui donne un effet d'ampleur plus important. Certainement grâce au "gros" cuivre de 2.5mm. De ce fait, il me semble que l’aiguë non pas en retrait, s’apprécie moins. C'est moins subtil en haut ça réduit l'aération que vous pouviez avoir. Ce câble est bien pour calmer un système "criard". Ça reste un très bon câble à ce prix !
Top câble.
Câble aujourd'hui devenu référence.
Parfait pour brancher mon caisson de basses Triangle Thétis sur mon ampli.
Graves profonds et tendus.
J'aime
Équilibre et douceur. Bon câble pour une écoute relax sans agressivité.
Je le préfère au 4 mm Orbit 240.
Franchement top
En remplacement de Deleycon CCA en 2.5 reliant mon Marantz 1050 revisé au WD40 Contact à mes Klipsch RP-600M c’est mieux. Après je ne pense par reconnaître la marque des cordes de guitare de Mark Knopfer
