By buying this product you get 44 loyalty points
The Viablue NF-S1 T8 is a stereo interconnect cable fitted with a 3.5mm jack connector and two RCA plugs, designed to connect a portable source or a device with a headphone output to an amplifier. Its two tinned OFC copper conductors, each made of 19 strands of 0.19mm, are combined with four layers of shielding, two silver-plated copper spirals and two ALU-PET foils, in order to limit interference during signal transmission.
Fitted with 24-carat gold-plated Viablue T8 connectors, the NF-S1 fits into Hi-Fi setups requiring an analog link between a jack output and an RCA input. Its ferrite filter, braided sleeve and Y-splitter respectively help attenuate high-frequency interference, protect the cable and guide the two channels to the RCA connectors.
Technical specifications
| Specifications | |
| Product type | Interconnect cable |
| Connectors | 2x RCA 1x Jack 3.5mm |
| Length | 5m |
| Shielding | |
| Conductor materials | OFC copper |
| Contact plating | Gold |
| Insulation | |
| General | |
| Color | Cobra |
| Package | 1x Viablue NF-S1 T8 |
| Length (m) | 5.0 |
| Shielding | Yes |
| Section (mm²) | N/A |
| Connector | Jack 3.5mm |
| Connector | RCA |
| Conductors Plating (Cable) | Tin |
