RAMM AUDIO ELITE 8 PREMIUM RCA Cables OCC Copper Cryo NBU Floating Ground Gold Plated 1m (Pair)
These high-end Ramm Audio Elite8 Premium RCA cables benefit from a very high quality design designed to ensure the best audio reproduction: OCC Copper conductors, cryogenic processing and floating mass, everything is done to promote optimal signal transmission.
By buying this product you get 28 loyalty points
Reference : 14125
289,00 €tax incl.
240,83 € tax excl.
Shipping date: 27-05-2026.
Ramm Audio Elite8 Premium Câbles RCA Cuivre OCC Cryo NBU Masse Flottante Plaqué Or 1m (La paire)
These RCA Ramm Audio Elite8 Premium high-end cables offer a very high quality design, thinked to ensure the best possible audio reproduction. Their conductors are made of pure OCC Copper, allowing excellent signal conductivity. These conductors also undergo cryogenic processing in order to further improve signal transmission quality.
The assembly of the cables is particular since they take advantage of the NBU technology for Noise Bypass Unit. Thus, they integrate a floating ground, consisting in separating the shielding ground from the signal ground, making the Elite8 Premium very quiet cables thanks to a reduced noise at the maximum. The shielding ground, connected on one side only, functions as a Faraday cage, protecting the conductors from the waves and interferences.
The Elite8 Premium ends with high quality connectors with gold-plated Tellurium Copper contacts, ensuring both excellent conductivity and high oxidation resistance.
Finally, a magnificent black and gold nylon sheath covers the cable, giving it better resistance to mechanical stresses and a magnificent aesthetic.
Since these cables have a floating ground assembly, they have a connection direction that must be respected in order to take advantage of their benefits and not generate noise. The connection direction is indicated by 3 arrows on the cables.
Ramm Audio Elite 8 : Composition diagram
Ramm Audio cables comparison
Elite 8
Elite-XTRA
Elite 72 (E72)
Mozart2
Cable geometry
Air-Inside© geometry with multi-layer shielding for excellent transparency and resolution, with less distortion and noise
Conductors
Single-core OCC copper
Number of conductors
3 individually shielded conductors
2 individually shielded conductors
Conductor composition
3 wires of 0.65mm, 0.60mm and 0.55mm individually wrapped in silk thread
2 x 0.5mm PP-insulated wires
3 x 0.5mm bare wires
1 x 0.6mm bare wire
Drain wire
3 x 0.6mm OFC monocrystalline copper strands
3 x 0.5mm OFC monocrystalline copper strands
1 x 0.65mm OFC monocrystalline copper wire
Dielectric
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
PP rods
Cotton filling
Conductors shielded by copper foil
Capacitance (pF/m)
140
203.51
203
155
Resistance (Ω/m)
0.024
0.03274
0.033
0.028
Inductance (µH/m)
1.4
1.31394
1.32
1.25
Characteristics
Natural, pure and transparent sound with smooth musicality and exceptional sound image. Quiet, excellent noise and interference rejection
Clean, natural signal transfer for dynamic performance with better-defined deep bass and smoother highs
Musical, transparent and smooth with excellent sound image
Sound image with highlighted voices. Natural sound with low distortion and noise
Connectors
Balanced connection, usually XLR
Single-ended connectors, usually RCA
Outer diameter
9.2mm
9.2mm
8.2mm
9mm
Product typeRCA Cable
ConnectorsMale RCA
Length1m
Cable conductors materialOCC Copper
Floating ground
Cryogenic treatment
Connectors contacts materialTellurium Copper
Connectors contacts platingGold
Cable diameterØ9mm
QuantitySold by pair (2 cables)
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorRCA
5 reviews
Impressions from the Ramm cable (turntable use)
From the moment I connected it, the difference was clear: the sound became more musical, fuller, and flowed more naturally. Any harshness or edginess disappeared, and the presentation came to life with a new sense of energy and presence. Everything felt faster, more fluid, and emotionally engaging. It made me want to rediscover my vinyl collection all over again. Very pleased!
This review has been posted for RAMM AUDIO ELITE 8 PREMIUM RCA Cables OCC Copper Cryo NBU Floating Ground Gold Plated 1m (Pair)
Tout simplement stupéfiant
L’amélioration sonore apportée par ce câble est tout simplement stupéfiante, ahurissante. Cela revient à changer de dac pour une gamme supérieure.
J’utilisais déjà les câbles ramm audio pour mes enceintes et mes alimentations. Je savais à quoi m’attendre, mais là on atteint un sommet.
Toutes les facettes de la reproduction sonore atteignent un niveau de réalisme incroyable (scène sonore, grave, médium, aiguë, détails, profondeur de scène, dynamisme…).
J’aime aussi les bagues de serrage qui assurent un contact parfait des connecteurs.
Il est beau également.
Seule ombre au tableau : j’ai reçu des câbles en vrac dans un sac en toile, mais les connecteurs n’étaient pas protégés… Étrange pour des câbles de cette gamme. L’impression d’avoir reçu du matériel reconditionné n’est pas très agréable…
sans compromis ...
J'ai attendu plusieurs mois avant d'émettre un avis ; le temps d'un bon rodage . Ce câble est très sensible à l'environnement . Au début j'avais un son très détaillé mais un peu dur ; en remplaçant les pieds de mon cd par des pointes les détails était toujours là mais avec un grand naturel . Scène sonore large ; on entends tous sans agressivité ; présence sonore réaliste mais pas caricaturale . Cable pour mélomane ; attention câble sensible qui pourra valoriser les défauts de votre système ; à associer avec des éléments de bon niveau .
produit rare !
Audiophile depuis de nombreuses années, j'ai essayé de très nombreux câbles de toutes marques et tous prix. Certains, très chers, m'ont laissé dubitatifs ou carrément frustré. D'autres m'ont
apporté une progression qualitative évidente. L'intérêt final se situant dans le juste rapport qualité prix.. Avec ce produit RAMM AUDIO, le rapport qualité prix est prodigieux (je pèse mes mots), car il fait mieux que beaucoup, coûtant le triple !
Une véritable bonne affaire à connaître et faire connaître.
Une Merveille
Acheté en remplacement d’un câble REGA pour assurer la connexion de mon pré amplificateur phono cube se de ma platine rega Rp6 à mon pré amplificateur Audio GD Master Singularity 11, ce fût une révélation. Tout est plus beau. Qualité des timbres, scène, positionnement des instruments. Évidemment, difficile de savoir ce qu’il apporte par apport aux autres câbles de la marque. Mais je ne peux que le recommander ! Vraiment une belle découverte !
These high-end Ramm Audio Elite8 Premium RCA cables benefit from a very high quality design designed to ensure the best audio reproduction: OCC...
