This chassis 100% aluminum is intended to accommodate a Raspberry Pi board and a X720 module.
When all these elements are used together, they form a true complete ultra compact ARM computer, with a power management hardware and software accessible from the front, long battery life and even an uninterruptible power system.
All functions related to the activity of the Raspberry Pi and the power module are displayed in real time through a series of indicator light.
Whether prototyping or simply upgrading your system, an extension is supplied with an external offset of the GPIO connector.
One can therefore take advantage of all the connectors of the Raspberry Pi via an external connector which is easily accessible (and can be removed) in order to use other extensions.
The case is supplied alone. The Raspberry Pi and the X720 are sold separately.
This product is only compatible with the Raspberry Pi 3. It is not compatible with Raspberry Pi 4.
| Specifications | |
| Type | Housing |
| Material | Aluminum |
| On / off button | Yes |
| External access to micro-SD card | Yes |
| Package Contents | |
| X720 enclosure | x1 |
| GPIO reference & switch board | x1 |
| Power button board | x1 |
| Power switch cap | x1 |
| Socket spanner 4mm | x1 |
| Spacer F/M M2.5 *21mm | x4 |
| Screw M3 *6mm | x6 |
