SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport
With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and high-performance components. In addition to a striking aluminium chassis, it is equipped with Sanyo DH870 laser optics and is capable of reading CD, SACD and MQA CDs. Finally, for the best possible experience, the ONIX Zenith XST20 is equipped with Gapless Playback technology, so you can enjoy your CDs without the slightest interruption.
4.3 / 5
By buying this product you get 209 loyalty points
Reference : 20661
2 090,00 €tax incl.
1 741,67 € tax excl.
Shanling ONIX Zenith XST20 CD / SACD / MQA CD Transport Sanyo HD870
Shanling ONIX Zenith XST20 : Front view
Please note that the Shanling ONIX Zenith XST20 does not have a DAC or analog output. That's why it's a CD transport. It has digital outputs only.
Shanling ONIX Zenith XST20: Sophisticated aesthetics
The ONIX Zenith XST20 is distinguished by its anti-vibration chassis made of CNC-machined aluminum alloy, giving it remarkable robustness and elegance. Its magnificent 3.4” touchscreen, combined with the Linux-based system, displays all essential information and facilitates navigation.
Shanling ONIX Zenith XST20 : on a cabinet
Shanling ONIX Zenith XST20 : macro view of the SACD logo
Shanling ONIX Zenith XST20: SACD and Gapless Playback
The ONIX Zenith XST20 is SACD compatible and features Gapless Playback technology, allowing you to enjoy superior CD quality with no gaps between tracks, as well as the ability to output in native DSD format thanks to the multiple digital outputs available.
Shanling ONIX Zenith XST20: State-of-the-art components
To give you the best possible listening experience, the ONIX Zenith XST20 uses the best possible internal components. It uses a Talema 25VA transformer for a clean power supply and a high-precision 48.1584 MHz internal clock for perfect signal synchronisation.
Shanling ONIX Zenith XST20 : Talema transformer
Shanling ONIX Zenith XST20 : I2S Pinout
Shanling ONIX Zenith XST20 : Pinout I2S
Product typeCD Transport
Outputs1x HDMI I2S
1x BNC
1x AES/EBU
1x Coaxial
1x Optical Toslink
1x USB-A
Supported CD formatsCD
Multi-layer SACD
Single-layer SACD
MQA CD
Screen3.4" Touch screen
Housing materialAluminum
Supported sampling rates
Optical Toslink / Coaxial / BNC / AESCD: PCM 44.1kHz
SACD: DSD64 DoP or D2P
IS2CD: PCM 44.1kHz
SACD: DSD64 Native
USBCD: PCM 44.1kHz
SACD: not supported
Power supply voltage220V AC
Dimensions320 x 240 x 71.5mm
Weight5.2kg
Package1x Shanling ONIX Zenith XST20
1x Remote control
1x Power cable
3 reviews
Sonne vraiment très bien ... mais n'est pas Gapless
Le problème avec le Gapless que j'ai évoqué précédemment est un problème Hardware, et ne pourra donc pas être résolu par un Firmware, rendant la promesse caduque
Par ailleurs de gros craquements dans les enceintes à la mise en route et à l'arrêt du lecteur. Chez moi cela a empiré avec le Firmware 1.9
Je réduis donc ma note face à la déception vu le prix de la machine
This review has been posted for SHANLING ONIX ZENITH XST20 CD / SACD / MQA CD Transport Sanyo HD870
L'adresse du site Head Fi
Introducing ONIX Zenith XST20 - High-End SACD Transport with true DSD output | Page 10 | Headphone Reviews and Discussion - Head-Fi.org https://share.google/JOatlSESuj2O2cFiM
Un drive à un doigt de la perfection
La construction est remarquable, massive et pourtant l'esthétique estraffinée, l'opération sans problème et le fonctionnement presque parfaitement silencieux même à faible distance.
La qualité sonore est exceptionnelle, avec une dynamique une ampleur de restitution de l'espace remarquable et l'apport du DSD parfaitement tangible en utilisant la sortie I2S.
Le seul défaut en l'état actuel du Firmware est que le Gapless ne l'est pas parfaitement
On suivra avec profit la résolution de ce défaut apparemment bien connu de la communauté sur le site Head Fi où intervient un staff de Shanling
With the Shanling ONIX Zenith XST20, Shanling has unveiled a new top-of-the-range CD transport with a luxurious design and...
