By buying this product you get 94 loyalty points
The SMSL VMV T2 is part of the brand's high-end product range. It's an MQA CD player that also acts as a digital interface, and features an optimized clock system. It is equipped with a P.A.S.S (Precison Access Servo System) playback system that natively supports MQA-CD. The SMSL VMV T2 also supports high-resolution PCM 32bit 768kHz and DSD512 streams, as well as full MQA decoding on some of its digital inputs. In fact, its USB-C and AES/EBU inputs supporting MQA enable it to act as a true MQA decoder. It also features an I2S output via HDMI, two AES/EBU outputs, as well as a Toslink optical output and a coaxial SPDIF output. There's also an external clock input and a clock output that can be directly connected to a DAC for excellent precision in your system. A Qualcomm QCC5125 chip also makes it a high-definition Bluetooth 5.1 receiver, with support for the following codecs: aptX, aptX HD and LDAC (24bit 96kHz).
The VMV T2, unlike the PL200, features I2S and AES digital outputs, as well as a complete interface for external clock and a digital processor. The PL200's only advantage is its analog outputs.
| SMSL PL200 VS SMSL VMV T2 | |||
| Interface | Inputs/Outputs | SMSL PL200 | SMSL VMV T2 |
| Analog outputs | XLR ouput | ||
| RCA output | |||
| 6.35mm jack headphone output | |||
| Digital inputs | CD player (MQA-CD) | ||
| HD Bluetooth receiver | |||
| USB input | |||
| AES/EBU input | |||
| Digital outputs | Optical Toslink and SPDIF coaxial | ||
| HDMI I2S output | |||
| Sortie AES/EBU ouput | |||
| External clock interface | External clock input (BNC) | ||
| Clock interface output (BNC) | |||
| Internal digital processor | |||
The SMSL VMV T2's "Precision Acces Servo System" reading system offers high reading accuracy and excellent response. An efficient anti-vibration system also prevents any potential disturbance caused by vibration. A playback mode allows you to play a disc with the cover open, for one of the most beautiful aesthetic effects. This CD player supports the MQA-CD format.
The SMSL VMV T2 supports full MQA decoding via its USB-C and AES/EBU inputs, enabling it to act as an MQA decoder. Its USB-C input also supports high-resolution PCM 32bit 768kHz and DSD512 streams.
The integrated clock alignment function enables the reconstruction of the clock of 44.1kHz and 48kHz audio recordings, for a marked improvement in the depth of the final sound reproduction of CDs and 44.1kHz and 48kHz recordings.
An external clock input lets you connect a 44.1MHz clock, a 10MHz stantard clock or an atomic clock to the SMSL VMV T2. An output is also available for connecting the SMSL VMV T2 clock directly to a DAC, for example. The impedance of the clock input can be set to 50 ohms or 75 ohms.
The SMSL VMV T2 features a Qualcomm QCC5125 Bluetooth 5.1 receiver chip, enabling it to support high-definition codecs: SBS, AAC, aptX, aptX HD and LDAC. The LDAC codec can transmit streams up to 24bit 96kHz, for unrivalled sound reproduction in wireless transmission.
| 1 | Player cover |
| 2 | CD retaining cap |
| 3 | CD holder |
| 4 | IR receiver |
| 5 | Indicator LED |
| 6 | Next/standby (long press) |
| 7 | Previous |
| 8 | Stop/Input selector (long press) |
| 9 | Play/pause |
| 10 | Display |
| 11 | Bluetooth antenna |
| 12 | USB-C input |
| 13 | I2S output via HDMI |
| 14 | Toslink optical output |
| 15 | SPDIF coaxial output |
| 16 | AES/EBU output 2 |
| 17 | AES/EBU output 1 |
| 18 | AES/EBU input |
| 19 | External clock input |
| 20 | Clock output |
| 21 | Power supply connector |
| Specifications | |
| Product type | CD Player MQA |
| Reading system | P.A.S.S |
| Inputs | 1x CD/MQA-CD player 1x USB-C 1x AES/EBU Bluetooth |
| Outputs | 2x AES/EBU 1x I2S via HDMI 1x Optical Toslink 1x Coaxial |
| USB transmission | USB 2.0 asynchronous |
| USB compatibility | Windows 7 / 8 / 8.1 / 10 / 11 (with driver) MAC OSX 10.6 ou + et Linux (without driver) Android et IOS (without driver) |
| Maximum output sampling rate | I2S via HDMI: PCM 32bit 768kHz, DSD512 Optical Toslink, Coaxial SPDIF, / AES/EBU: 24bit 192kHz |
| MQA support | Up to MQAx8 (384kHz - automatically converts to 192kHz for SPDIF) |
| Supported Bluetooth codecs | SBC, AAC, aotX, aptX HD, LDAC (24bit 96kHz) |
| EXTERNAL CLOCK INTERFACE | |
| Frequency | 44.1kHz or 10MHz |
| Input impedance | 50 ohms or 75 ohms |
| Waveform | Square or sinusoidal |
| Level | Square: TTL Sinusoidal: > 1Vrms |
| CLOCK OUTPUT INTERFACE | |
| Frequency | 44.1kHz or 48KHz (depending on audio source) 44.1kHz (for CDs and DSD) |
| Output impedance | 75 ohms |
| Level | TTL |
| General | |
| Power supply | 100-240V AC |
| Energie consumption | 15W Standby: < 0.5W |
| Dimensions | 280 x 51 x 236mm |
| Weight | 3.52kg |
| Color | Black |
| Package | 1x SMSL VMV T2 1x Antenne Bluetooth 1x Câble d'alimentation 1x Câble USB 1x Télécommande |
Two modes are available for I2S audio output via HDMI for greater compatibility with different DACs.
