BURSON AUDIO SUPREME SOUND SS OPAMP V6 Single Discrete OPA (Pair)
Reference : 12176
79,00 €tax incl.
65,83 € tax excl.
BURSON AUDIO Classic SINGLE PAIR X2
- AOP with discrete transistors mono in pairs-
burson v6 discret audio AOP
High resolution, dynamic, balance
The AOP Burson V6 ViVid and Classics are evolutions of the V5 series with a particularly good sound balance. They will bring opening, timbre, dynamics and sound image in three dimensions to any Hifi devices compatible with support DIP8 compatible NE5534 single or NE5532 dual according to the versions.
Improved design
OfferingImproved heat protection and improved heat protection The discrete AOP Burson V6 are now also stable on the single stage stage buffers as on the I / V voltage stages of the DAC stages. The Burson v6 are thus of exemplary stability now equipped with 0.5% metal film resistors with two stages of hand-selected FET transistors. The version VIVID brings an additional definition, the classic version an extra stamp.
, font-weight: normal; "> font-size: 22px; font-family: Muli, Arial;REVERSE PROTECTION SYSTEM
A new protection system allows greater reliability of these high-performance discrete AOPs. The Burson AOP V6 are thus designed to survive any assembly accidents upside down on DIP 8 support.
TECHNICAL CHARACTERISTICS
SPECIFICATIONS
  • Minimum Voltage Required: + - 3.5V / 7VDC
  • Maximum Voltage: + - 16.5V / 33VDC
  • Current consumption: single 7mA, dual 14mA
  • Frequency response: 20Hz - 20kHz (-0.2dB)
CONNECTORS
Contacts:
  • Types DIP 8 plated Gold 8 pins
VARIOUS
  • Weight: 10gr x2
  • Dimensions: 29x12.4x14.5mm (excluding socket)
Compatibility for models:
Dual Op-amps type 5532:
AD823, AD823AN, AD8066, AD823AN, AD823, AD823AN, AD812A, AD827C, NJM4560, NJM5532, NJM4558P, OP275, OPA1612, OPA2277PA, OPA2132, OPA2134, OPA2604, JRC4558, RC4558D, RC4558P, TL052, TL072, MUSES01, MUSES02, MUSES8820, MUSES8920, MUSES8832.
Single Op-amps type 5534:
NE5534, LT1122, TL071, OPA134, OPA627, AD811, AD829, AD844, OPA604, AD8610, AD711, AD797, LME49990, LME49710.
OPA TypeSingle
5 reviews
strange fruit
This is my first discrete test in an op amp topology. The pair replaced the 5534s in an evo sabre dac. (plug n play easy solution- no need for extension). After a few hours burn-in (they do need that) you get a holographic sound with mids and highs having the tonality and presence of a set amplifier. After a quick change to the previous 5534s the difference is quite audible. I am intrigued to get the vivids too but for now the supremes are doing the trick just fine. Needless to say that my beloved evo sabre dac shines in my main system.
This review has been posted for BURSON AUDIO SUPREME SOUND SS OPAMP V6 Single Discrete OPA (Pair)
Impressionnant
Installes sur un Fostex Hp 8 Ac Mk1. Impressionnant : plus de largeur, de dynamique sur l’écoute au casque . En revanche pas de changement sur la sortie ligne ( mais c’est logique, les Aop ne sont pas sur ce trajet).
Attention à bien prendre les prolongateurs en plus . Ça évite de mettre les autres composants en tension.
Transfigure mon DAC Fostex HPA8C
J'ai remplacé les AOP de conversion d'origine de mon DAC par ces AOP Burson.
J'avais choisi de garder des connexions les plus courtes possibles, en plaçant les Burson en lieu et place des AOP d'origine. Cceci a nécessité pour un AOP de déplacer un condensateur de 3 mm. Je n'ai pas essayé les prolongateurs. La définition et justesse sonore ont énormément progressé. Au départ j'imaginais mon DAC de 2014 dépassé mais suite à cette évolution et au remplacement des AOP de l'étage de sortie par des AOP Sparkos je ne vois plus la différence avec les DAC modernes autour de 2000 €. Je recommande !
burson v6 classic
en etage de sortie sur un pre amp c1 de kenwood super son
Super Burson
Ont remplacé avantageusement deux LME49710 sur un DAC AKM AK4497, meilleure définition, image plus large et profonde, qualité des timbres. ls prennent peu de place, s’adaptent facilement au voltage. Une période de rodage est nécessaire.
