Extension for OPA DIP8 Copper OCC Silver 30mm
This extension for DIP8 PDO will be particularly useful to mount PDOs on PCBs that leave little space for this component or to mount larger PDOs, such as the Dexa Discrete Audio Opamp. Indeed, this extension of 30mm will make it possible to raise the component or to orient it differently, in order to integrate it into your project, whatever the constraints of space.
3.8 / 5
Reference : 13046
11,50 €tax incl.
9,58 € tax excl.
Shipping date: 29-09-2026.
AOP extension
AOP DIP8 Extension OCC Copper Silver Plated 30mm
Extension AOP DIP8 Cuivre Argent 30mm
In addition, the conductors of this extension are OCC copper with Silver plating, for excellent signal conductivity up to your PDO.
This product can be bent slightly, but this must be done with care and attention.
CompatibilityAOP DIP8 extension
MatreialCopper
Silver plated
Length30mm
OPA TypeN/A
5 reviews
Very fragile, broke immediately.
As soon as I began to bend the wires, one of them broke off and ruined the extender. The extender I received looks nothing like the picture shown here. It has black protectors in both ends, making it even more difficult to bend the wires correctly. This was my first attempt of rolling op-amps and I am not sure I am going to to do it again.
Hello,
We have never had a problem with this accessory.
In the absolute it is not really designed to be bent or twisted in any ways.
This review has been posted for Extension for OPA DIP8 Copper OCC Silver 30mm
Quality product. Great value.
Good, sturdy, quality wiring.
I used it to solder and seperate little circuit around the sparkos ss3602, powered by seperate power supply (seperate from digital part of the DAC.). Spectacular improvement over the sparkos directly dropped in.
adaptateur
fait ce qu'il faut faire m'a permis de monter le bourson v6 vif dans un petit espace (sans lui je n'aurais pas pu le faire) juste faire attention quand il faut se pencher.pour le reste excellent
Big improvement
Well made.no Short on signals.
prolongateur dip 8
Fragile et cher ,ne peut pas être courbé,sinon il casse ,s' utilise seulement droit ,tenir compte de la hauteur du coffret.
Bonjour,
Le prolongateur peut être courbé, mais de façon délicate et avec précaution.
This extension for DIP8 PDO will be particularly useful to mount PDOs on PCBs that leave little space for this component or to mount larger PDOs,...
