SPARKOS LABS SS2590 PRO Single Discrete OPA (Unit)
After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be found in studio equipment or recording devices, such as the API2520 operational amplifier or the Jensen 990. After numerous tests and measurements, SparkoS Labs decided to offer a much more efficient OPA.
Reference : 13897
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 23-09-2026.
If you wish, this OPA is also offered in a double version, pre-assembled and soldered on its DIP8 adapter : SPARKOS LABS SS2590 PRO Dual Discrete OPA.
SparkoS Labs SS2590
SparkoS Labs SS2590 AOP Discret Simple (Unité)
The brand's first observation when studying these OPA models is the presence of old components, particularly transistors, which are often not very reactive and offer a tasteless reproduction. The SS2590 uses the transistors with the best reactivity and highest gain available today. Where other brands mostly use models between 20 and 50MHz, SparkoS Labs uses 300MHz transistors.
In addition, the brand uses a unique and exclusive bipolar compensation technique to maximize open loop gain over the entire bandwidth. This technique increases amplifier accuracy and lower THD while maintaining a high scanning speed, ensuring a better transient response and a more natural dynamics.
SparkoS also worked on the noise level, which is too high on many discrete OPA. On the SS2590, RE resistors are used at the input stage to benefit from their linearity. Noise has been reduced with a parallel circuit of the input transistors.
SparkoS Labs Technology
PrEsentation :
The SS2590 discrete OPA is based on the Lin 3 Stage topology which consists of a pair of differential input stages, a gain stage (VAS) and a Class A output stage with two pole compensation. All active components are bipolar junction transistors (BJTs) offering the best linearity that silicon components can offer. In addition, the components are fully protected against overcurrents by active current limiting circuits in the ain and output stages, as well as against large input voltage differences using Schottky diodes. In short, the OPA consists of 35 BJTs, 37 resistors, 7 capacitors and a few diodes.
Input Stage :
The input stage of the OPA integrates a double pair of NPN bipolar junction transistors (BJTs) paired and cascoded. This arrangement using several parallel input transistors reduces the noise of the input stage to 1.5nV√Hz over the entire bandwidth. The input offset voltage is set at the factory to exceed 300µV @ +/-18Vdc. A Wilson cascoded current mirror is used as an active load to obtain a precise current correspondence between the input transistors.
Gain Stage (VAS) :
The SS2590's gain stage is a Darlington cascode providing very high linearity and high open loop gain. The polarization voltage of the cascode is derived from precision shunt references, having a dynamic impedance and a much lower noise than the low voltage Zener diodes used to derive this polarization voltage. In addition, the current of the gain stage is limited, allowing a much better stability.
Compensation :
The SS2590 uses a 2-pole component architecture that provides the best possible open loop gain while providing high resistance to capacitive loads. A high loop gain corrects distortion when the loop is closed. This 2-pole compensation, although more efficient than 1-pole diagrams, is not often used in integrated circuit OPA due to the difficulty of manufacturing.
Output Stage :
The output stage is a common Darlington push-pull collector (emitter-follower) polarized in class A with a stable current of 16mA. Due to the push-pull action, the output stage can supply or absorb a current of 32mA while remaining in Class A. It will automatically switch to Class AB if more power is required. A limitation system is used in the output stage to protect it from possible overload. Large copper areas under the PCB are used as heat sinks in order to properly dissipate heat.
Pinout & Dimensions
Product typeClass A Single Discrete OPA
Open Loop Gain165dB
CompensationTwo poles compensation
Output current in Class A+/-32mA
Max output current+/-250mA
Unity-Gain bandwidth10MHz
Noise1.5nV√Hz up to 20kHz
Offset< 1mV
Supply voltage+/-9V to +/-24V
CompatibilityAutomated Processes API2520, API2525
Jensen and John Hardy 990 Series
Sound Skulptor SK Series
Purple Audio KDJ Series
Five Fish Studio Discrete Series
Avedis Audio 1122
Seventh Circle Audio SC Series
Yamaha NE Series
Rogue 5 Series Discrete OPA
Whistle Rock Audio Series
Warm Audio Discrete Series
Dimensions27.94 x 27.94mm
OPA TypeSingle
6 reviews
Exceptionnel
Je possède un excellent DAC Erato dont la sortie analogique est en classe A et composants discrets avec toutefois la présence de 2 AOP simple !
Remplacement indispensable pour qu'un circuit audio donne son maximum !!!
This review has been posted for SPARKOS LABS SS2590 PRO Single Discrete OPA (Unit)
Excellent produit !
J'ai essayé le couple Sparkos 3601-3602 puis le couple Staccato OSHS - OSH-DHb sur un ampli qui se compose de 4 simples AOP, et d'un Double. Eh bien, le top c'est ce SS2590, c'est incroyable de dynamique, de précision, les timbres sont parfaitement justes, c'est très équilibré, je ne vois vraiment pas comment ça pourrait être mieux. Et c'est instantané, pas attendu des heures de "rodage" pour donner mon avis, les modèles précédents sont totalement enterrés.
AOP de rêve - Le Nirvana existe !!
Excellent AOP que ce ss2590, tout simplement bluffant !! Pour info, J'ai des enceintes haut rendement DIY à base de Altec 414 et de Moteur TAD - TD 2001+ pavillon DIY rendement 100 db. Pour la source, j'ai un boitier DIY avec Raspberry PI 4 + Alimentation Ian Canda et Rockloker de la même marque + filtre actif Najda le tout relié exclusivement en I2S. Après avoir testé le SS3602 (voir avis sur le sujet), j'ai décidé de faire l'acquisition de 2 AOP SS2590 en espérant obtenir un petit gap au niveau des résultats. Bien que certains disent qu’il y a un petit gain entre ces deux AOP je ne suis pas du tout d’accord. Pour moi, bien que le SS 3602 soit excellent ici on atteint le Nirvana !!! Parlons changements, dès le début il y a un grave comme je n’ai jamais entendu (mes Altec 414 sont devenu des 416), l’impression d’avoir des 38 cm au lieu des 30 cm, est plus que sympathique. Pour faire simple cet AOP à la même signature sonore que le SS 3602 mais avec un niveau de fous normal il fonctionne toujours en pur Class A !! Les transitoires sont là avec un niveau de fous et les silences se font silence comme jamais. Toute la bande sonore est très naturelle, dynamique, sans artefacts, colorations ou agressivité dans les aigus. Cela amène mon préampli +filtre numérique à un niveau de fous !! je n’ose même pas imaginer quel serait le prix dans le commerce de mon préampli surement entre 6 et 10 000€. Vive le DIY et un grand merci à Audiophonics pour leurs conseils et leur disponibilité.
Jean-François.
Qualités sonores exceptionnelles.
Ce circuit SPARKOS Pro est encore très supérieur musicalement à la version de base pourtant déjà remarquable.
Il transfigurera n'importe quel montage utilisant un AOP.
Bien alimenté on peut comparer sa qualité audio à celle des circuits discrets des préamplificateurs audiophiles les plus haut de gamme.
Un réglage d'offset de sa sortie ajoute encore à son universalité d'emploi.
SUPERBE !
Étonnante amélioration lorsque comparé à la version classique SS3601 déjà supérieure à la plupart des AOP .
Cette version PRO SS2590 sublime littéralement le rendu sonore sur tous les critères avec en prime une dynamique semblant sans limite grâce à un travail en Classe A passant de 15 à 32 mA, donc courant max doublé.
Cela qui permet de rester en vraie Classe A même sur les fortés et cela s’entend !
Bel investissement ; ne pas hésiter !
Ch B
After the undeniable success of the SS3601 and SS3602 discrete OPA, SparkoS Labs focused on discrete OPA that can be...
