PCB for Potentiometers Input / Output Connection
Convenient, this printed circuit board will allow you to simply make a potentiometer input/output connection. It is compatible, for example, with potentiometers ALPS RK27, VRB, VRA, 100KAX2, etc.
Reference : 8525
0,90 €tax incl.
0,75 € tax excl.
Shipping date: 24-06-2025.
PCB pour Potentiomètre Raccordement Entrées / Sorties
The PCB is delivered alone. The potentiometers are sold separately.
Product typePCB for potentiometer
Dimensions50.6 x 31.6mm
ShaftNC
ChannelN/A
Resistance (Ohm)N/A
Tolerance (%)N/A
11 reviews
Good
Very useful and convenient.
This review has been posted for PCB for Potentiometers Input / Output Connection
PCB for ALPS
Everything as I imagined.
Fast delivery..
Can only recommend it ..
Thanks to the team for the support
Geniale
Avete mai provato a montare un potenziometro su un pannello e cablare insieme i cavetti schermati che devono andare al preamplificatore ?
Con questa semplicissima schedina è tutto molto più semplice, pulito e ordinato
Davvero molto comoda, per la sua spesa ne vale davvero la pena
Spedizione per l'Italia in tempi davvero molto rapidi, ed imballaggi fatti davvero con cura : complimenti AUDIOPHONICS !
Best way to connect potentiometer
Quality and practical
Good quality PCB, which is small enough to fit in various amps. Especially useful for fitting larger pots in old amps that had small pots.
Convenient, this printed circuit board will allow you to simply make a potentiometer input/output connection. It is compatible, for example, with...
