VISHAY DALE Stereo Switching Potentiometer Shunt 23 Positions Notched Axis Logarithmic Ø6mm 10K Ohm
This type of shunt switching potentiometer is ideal for the design of transparent and dynamic hand-held preamplifiers. This conventional switched resistance technology is superior to carbon potentiometers with higher reliability.
4.8 / 5
Reference : 12373
23,90 €tax incl.
19,92 € tax excl.
Shipping date: 29-09-2026.
This type of potentiometer is superior to the potentiometers with carbon track because the signal crosses only 2 metal resistors in series.
Wear is also much less important. It is especially advisable on the assemblies claiming the highest possible fidelity on low noise preamplifiers, solid-state headphone amplifiers with discrete component.
Main Features :
  • Shunt-type resistor switch potentiometer base
  • Logarithmic
  • 23 positions
  • High quality metal resistors Vishay Dale.
  • Resistance 10K. Li>
  • Overall diameter: 37mm
  • Body Diameter: 29mm
  • Off-axis length: 63mm
  • Length of the axis: 10mm
  • Diameter of the axis of the potentiometer: 6 mm
  • Drilling diameter: 11 mm
  • Weight: 43gr
  • Delivered: unit
Schéma de branchement potentiomètre commuté shunt vishay dale 23 positions stéréothumbs%206.jpg
ShaftNotched
Channel2 (Stereo)
Resistance (Ohm)10000.0
Tolerance (%)N/A
4 reviews
Good - but had a mechanical mistake in the beginning
I measured it roughly and in position 1(on one side only) I had infinity resistance - not good! = means it gives out the full volume in the position of zero volume! It took me approx. half an hour to dismount it and to find the "microscopical" mistake - one plastic-washer was inverted and so the position of the riding contact was ½ millimeter in the wrong position... Now it's fixed and gives me zero Ohm at position one. (-::
This review has been posted for VISHAY DALE Stereo Switching Potentiometer Shunt 23 Positions Notched Axis Logarithmic Ø6mm 10K Ohm
Très bien mais
Au niveau de la qualité au niveau du son, extra .
La différence est époustouflante. Le mais, très très dur a manoeuvrer, peut de chance que dans le temps il ce rode. Mais très content de l'achat.
un grand classique
Attention à ce que les résistances, par ailleurs bien alignées, bien soudées, ne touchent pas les deux vis et écrous du carter, les écarter un peu si nécessaire. La rotation est un peu dure (rodage ?), c'est le prix à payer pour des contacts de qualité. Remplace avantageusement les modèles à pistes, mais on ne pourra le motoriser, trop de force pour faire tourner.
EXCELLENT INVESTISSEMENT !
Ce potentiomètre a avantageusement remplacé un modèle conventionnel.
L'écart est notable; on gagne en précision, détails et distorsion.
En bref le rendu est beaucoup plus transparent.
Vu le prix des résistance sDALE à l'unité, on peut considérer que le prix du potentiomètre qui en comporte une cinquantaine est dérisoire (surtout vu l'excellent résultat).
This type of shunt switching potentiometer is ideal for the design of transparent and dynamic hand-held preamplifiers. This conventional switched...
