ON MC7918CTG Linear Voltage Regulator LDO -18V 1A (Unit)
The MC7918CTG is an LDO negative linear voltage regulator with a fixed -18V output. This regulator can be integrated in many projects. It incorporates current limiting, thermal protection and safety zone compensation.
Reference : 14395
1,80 €tax incl.
1,50 € tax excl.
Shipping date: 11-09-2026.
ON MC7918CTG
ON MC7918CTG Régulateur de Tension LDO -18V 1A (Unité)
The MC7918CTG is an LDO negative linear voltage regulator with a fixed -18V output. This regulator can be integrated in many projects. It incorporates current limiting, thermal protection and safety zone compensation making it extremely robust under most operating conditions. With a suitable heatsink, it can deliver a current of 1A.
Product typeLDO Linear Voltage Regulator
Output typeFixed
Minimum input voltage-35V
Maximum input voltage-21V
Nominal fixed output voltage-18V
Output current1A
Trigger voltage1.3V
Output voltage tolerance4%
Case typeTO-220
Number of pins3
Operating temperature0°C - 125°C
Output voltage (V)-18.0
Output current (A)1.0
Input voltage (V)-35.0
Input voltage (V)-21.0
The MC7918CTG is an LDO negative linear voltage regulator with a fixed -18V output. This regulator can be integrated in many projects. It...
