By buying this product you get 27 loyalty points
The Arylic A100 is a connected amplifier designed to offer exceptional power and versatility. It delivers up to 2x100W under 4Ω in stereo or 200W under 2Ω in mono, integrating easily into various Hi-Fi systems thanks to its extensive connectivity.
With its RJ45 Ethernet port, Wi-Fi connection and Bluetooth 5.0, the A100 ensures seamless integration into your installations. Its compatibility with a wide range of network protocols and streaming services makes it particularly flexible and capable of meeting the needs of demanding music lovers.
The A100's main asset is its connectivity. It supports Airplay, Spotify Connect, UPnP, DLNA and Qplay protocols. What's more, it's also compatible with a host of streaming services such as Spotify, Tidal, Amazon Music, Qobuz, Napster and many others.
The A100 offers 2x100W amplification at 4Ω. However, you can also transform this amplifier into a powerful 200W mono block thanks to a switch on the rear panel.
The A100 can be used with the Go Control app available on Android and iOS. This lets you remotely control your music playback, as well as setting up a multiroom system. The control app also features a 10-band equalizer, so you can customize your listening experience to suit your preferences.
Arylic has also equipped its A100 connected amplifier with a phono input so you can enjoy your vinyl collection. This phono input is compatible with turntables with MC and MM cells.
Product type | Connected amplifier |
Inputs | 1x Stereo RCA 1x Phono MM/MC input 1x Coaxial 1x Optical Toslink 1x RJ45 2x USB-A 2x Mic input WiFi Bluetooth FM Radio |
Outputs | 2x Speaker terminals |
Output power | Stereo: 2x100W @ 4Ω / 2x60W @ 8Ω Mono: 1x200W @ 2Ω |
Speaker impedance | 4Ω-8Ω |
Frequency response | 20Hz - 20kHz |
THD+N | 0.03% |
SNR | 91dB |
Transmission protocols | Spotify Connect AirPlay UPnP DLNA Qplay |
Compatible streaming services | Spotify Tidal Qobuz Pandora Napster AmazonMusic iHeartRadio BBCRadio TuneIn RadioParadise vTuner QQmusic |
WiFi | IEEE802.11 b/g/n 2.4G |
Ethernet | 10/100M RJ45 |
Bluetooth version | 5.0 |
Supply voltage | 115-230V AC 50/60Hz |
Dimensions | 248 x 215 x 64mm |
Weight | 3.9kg |
Color | Black |
Package | 1x Arylic A100 1x RCA cable 1x Power cable 2x Antennas (BT/WiFi) 1x FM antenna |
Input | USB |
Input | FM |
Input | Jack 3.5mm |
Input | Optical |
Input | RJ45 |
Input | WiFi |
Input | RCA |
Input | SPDIF |
Input | Bluetooth |
Input | Phono |
Output | Speaker terminal |
Color | Black |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | FDA |
Amplifier chip | N/A |
Power (W) | 100.0 |
Power (W) | 200.0 |
Remote Control | No |
