HIFIBERRY DAC+ DSP DAC Board with DSP for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC+ DSP combines both a digital to analog converter based on a Burr Brown DAC chip - with a digital input and output, as well as an analog output - and a powerful 300MHz DSP processor. The latter, working with SigmaStudioStereo, will allow you to adapt the sound reproduction of the module to your listening and your equipment.
Reference : 15644
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 05-05-2026.
HiFiBerry DAC+ DSP
HiFiBerry DAC+ DSP Module DAC avec DSP pour Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC+ DSP combines both a digital to analog converter based on a Burr Brown DAC chip - with a digital input and output, as well as an analog output - and a powerful 300MHz DSP processor. The latter, working with SigmaStudioStereo, will allow you to adapt the sound reproduction of the module to your listening and your equipment. It has been designed to work with a Raspberry Pi, with a 40 pins GPIO input.
1Analog DSP input
2External I2S DAC output
3Selfboot
4Digital DSP inputs and outputs
5Optical Toslink input (up to 96kHz)
6Optical Toslink output (up to 192kHz)
7RCA Output
DSP Analog inputs (P4)
The analog inputs allow a direct connection to the DSP. However, it is not an ADC. The inputs are designed to use an external analog controller as variable resistors to control a DSP program. It is therefore necessary to create your own DSP program to use this function.
GND12Power supply +3.3V (up to 0.1A)
AUX ADC134AUX ADC0
AUX ADC356AUX ADC2
I2S EDAC Output
This output provides the I2S digital data stream that is used by the built-in DAC.
+5V12GND
Raspberry Pi SDA34Raspberry Pi SCL
I2S BCLK56I2S DATA
I2S LRCLK78MCLK
DSP Digital inputs and outputs
This connector gives access to additional I2S inputs and outputs of the DSP.
+3.3V (up to 0.2A)12GND
MCLK34GND
LRCLK OUT156BCLK OUT1
DATA OUT178GND
LRCLK OUT2910BCLK OUT2
DATA OUT21112GND
LRCLK IN21314BCLK IN2
DATA IN21516GND
Product typeDAC board with DSP
InputsGPIO 40 pins
1x Optical Toslink
Outputs1x Optical Toslink
1x Stereo RCA
CompatibilityRaspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero
Max output voltage2.1Vrms
SNR112dB
THD+N-93dB
Frequency response10Hz - 70kHz
Supported sampling ratesPCM up to 24bit 192kHz
Max IIR filters> 1000
Dimensions5.5 x 6.5 x 2.5cm
Weight40g
Consumption< 3W
InputGPIO
OutputOptical Toslink
DAC / ADC ChipBurr Brown
Max sampling rate192kHz
J'ai acheté cette carte DAC + DSP pour essais
J'ai acheté cette carte, car elle figurait dans la liste Volumio des DAC compatible; mais aussi pour tester une puce Burr-Brown ( je suis plutot AKM ); enfin pour ses fonctionnalités : Sortie analogiques RCA, Sortie numérique sur SPDIF optique, entrée numérique optique. Plus DSP; mais cette fonction ne m'intéresse pas.
Voici mon ressentis
Sortie analogique : bof ....un peut brut de décoffrage
Sortie numérique Optique : WAOUH.....relié à un Topping D90. Et ça passe le 24 bits
Cette carte va donc remplacer définitivement mon HIFIBERRY Digi
Les autres fonctionnalités ne m'intéressent pas.
Bien sur cet avis n'engage que moi; mais je tenais à faire part de cette trouvaille.
Bien audiophilement
This review has been posted for HIFIBERRY DAC+ DSP DAC Board with DSP for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC+ DSP combines both a digital to analog converter based on a Burr Brown DAC chip - with a digital input and output, as well as an...
