HIFIBERRY DAC2 ADC PRO DAC PCM5122 / ADC PCM1863 Module for Raspberry Pi
The HiFiBerry DAC2 ADC Pro is a digital/analog and analog/digital converter module specially designed for use with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero, 5). This sound card therefore features both analog and digital inputs, offering a wide range of uses, whether for recording or audio playback.
Reference : 19984
99,90 €tax incl.
83,25 € tax excl.
Shipping date: 16-07-2025.
HiFiBerry DAC2 ADC Pro Module DAC PCM5122/ADC PCM1863 for Raspberry Pi Burr Brown 24bit 192kHz
HiFiBerry DAC2 ADC Pro picture
The HiFiBerry DAC2 ADC Pro is a DAC/ADC module for digital-to-analog and analog-to-digital conversion specially designed for use with a Raspberry Pi (A+, B+, 2B, 3B, 3B+, 4B+, Zero, 5). This sound card therefore features both analog and digital inputs, offering a wide range of uses, whether for recording or audio playback.
The module is based on two Burr Brown chips, a PCM5122 DAC chip and a PCM1863 ADC chip, enabling it to support PCM streams up to 32bit 192kHz. An optimized clock circuit completes the package, reducing jitter. The HiFiBerry DAC2 ADC Pro is also compatible with the HiFiBerry DSP add-on and Alsa Mixer for volume control.
Signal input is via 40-pin GPIO (digital) or 3.5mm jack/PCB connector (analog), while output is via RCA or PCB connector. The module is powered by the 40-pin GPIO, and therefore by the Raspberry Pi, and a PCB connector enables an additional 5V supply to be taken from the Raspberry Pi.
Key features:
  • Stereo input and output
  • Dedicated 192kHz/24bit high quality Burr-Brown DAC
  • Dedicated 192kHz/24bit high quality Burr-Brown ADC
  • Hardware volume control for DAC and ADC. Input and output parameters can be controlled using “alsamixer” or any application supporting ALSA mixer controls.
  • Supports HiFiBerry DSP module (sold separately).
  • Connects directly to the Raspberry Pi, without the need for an additional cable.
  • No soldering required, just connect to a Raspberry Pi. HAT-compliant.
  • Compatible with any Raspberry Pi with a 40-pin GPIO.
  • Three ultra-low-noise linear voltage regulators for optimum audio performance.
  • Low jitter clock for optimized clock signal.
  • Microphone bias voltage for use with electret microphones.
  • No anti-aliasing filter on the input circuit to offer the best recording bandwidth.
  • Complies with HAT format. EEPROM for automatic configuration.
  • Gold-plated RCA output connectors.
  • Supplied with spacers and screws for RPI mounting.
HiFiBerry DAC2 ADC Pro overview
140-Pin GPIO
2PCB connector +/-5V
3Microphone bias jumper*
4Balanced/unbalanced analog input on PCB connector (J4)
53.5mm jack analog input
6Stereo RCA output
7Analog output on PCB connector (J5)
8PCB connector for DSP
*You need to close both jumpers to provide a bias current suitable for a microphone.
HiFiBerry DAC2 ADC Pro: focus on input and output on PCB connectors
4 : Balanced/unbalanced analog input on PCB connector (J4)
In R-12In R+
GND34GND
In L+56In L-
7 : Analog output on PCB connector (J5)
+5V12R
GND34GND
+5V56L
Product typeDAC/ADC module
DAC/ADC chipsDAC PCM5122
ADC PCM1863
Inputs1x 40-pin GPIO
1x 3.5mm jack
1x Balanced/unbalanced analog input on PCB connector
Outputs1x Stereo RCA output
1x Analog output on PCB connector
CompatibilityRaspberry Pi A+, B+, 2B, 3B, 3B+, 4B+, Zero, 5
Max. input voltageUnbalanced: 2.1Vrms
Balanced: 4.2Vrms
Max. output voltage2.1Vrms
SNRDAC : 110dB
ADC : 112dB
THD+NDAC : -93dB
ADC : -90dB
Frequency response10Hz-70kHz (-3dB)
Input gain-12db to 32dB
Supported sample ratesPCM 24bit 192kHz
Power supplyVia Raspberry Pi
Power consumption< 0.3W
Dimensions5.5 x 6.5 x 1cm
Weight30g
Package1x HiFiBerry DAC2 ADC Pro DAC/ADC module
InputPCB Connector
InputGPIO
InputJack 3.5mm
OutputPCB Connector
DAC / ADC ChipPCM1863
DAC / ADC ChipPCM5122
Max sampling rate192kHz
HIFIBERRY DAC2 ADC PRO DAC PCM5122 / ADC PCM1863 Module for Raspberry Pi Burr Brown 24bit 192kHz
The HiFiBerry DAC2 ADC Pro is a digital/analog and analog/digital converter module specially designed for use with a Raspberry Pi (A+, B+, 2B, 3B,...
