IAN CANADA TRANSFORMER I / V PCB Kit V2 output circuit for audio transformers
Reference : 14324
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 22-07-2025.
Ian Canada kit Transformer I/V V2
Output Stage module for audio transformer kit
This kit from Ian Canada allows you to mount your own output stage for ES9038Q2MPi and Es9028Q2MPi DAC. Its input connection is in fact based on a XH (2.54mm) 2x5 connector.With suitable connector it may also be mounted on any  digital / analog conversion stage devoid of output stage.
It consists of a single PCB with two slots for accommodating the pair of audio transformers.
The connectors and other electronic components (resistors) are supplied by default with the kit and must be installed by the user. This arrangement requires a soldering iron and some knowledge in electronics.
On the PCB one can find two pairs of pads for installing additionnal capacitors. This step is optional and the capacity of capacitors is to be determined by trying and testing.
Transformers are sold separately.
Dimensions & distances
TypeOutput stage module
InputIn analog stereo (2x5 Pin XH2.54)
OutputsBalanced Stereo XLR
Stereo Unbalanced RCA
Supported audio transformerLundahl LL1544A (not included)
Package Contents
PCBx1
Dale resistors CMF60 510Ω 1%x2
2x5 PCB Connector (XH 2.54mm)x1
XLR PCB Connectorx2
RCA PCB Connectorx2
InputGPIO
super
après bien des essais avec des AOP cette sortie I/V de dac est superbe: simple (il n'y a pas a choisir une montagne d'AOP) ampleur du son, détail… bien pour mon système.
This review has been posted for IAN CANADA TRANSFORMER I / V PCB Kit V2 output circuit for audio transformers
