ALLO DIGIONE Raspberry Pi 2 / 3 / 4 Digital Interface SPDIF
4.9 / 5
Reference : 12067
135,00 €tax incl.
112,50 € tax excl.
ALLO DIGIONE
Digital interface
Interface digitale Allo DigiOne
High quality digital interface
The Allo DigiOne digital interface is currently the best SPDIF digital output for Raspberry Pi. It will connect directly to the GPIO of your Raspberry Pi 2 / 3 / 4 to improve the performance of your system, lowering the jitter to a minimum. Equipped with a DIR WM8805 chip, it ensures the digital transfer of the Raspberry Pi with High Fidelity.
Indeed, the DigiOne includes high quality components that will take your music to new horizons with 10 LDO regulators, 12 LPF filters, low noise DC/DC converters, galvanic isolation, low drift NDK oscillators (clocks). The outputs of the Raspberry Pi and DIR WM8805 are separated by a digital isolator to avoid degrading the signal.
The DigiOne benefits from a 75 Ohm BNC output and a 192 kHz 24-bit digital Coaxial RCA output. The jitter rate for a SPDIF interface is one of the lowest on the market with 0.4PS. Most of the competitors are over 1000ps (1ns)! The noise is reduced to 50uV.
Download Volumio for DigiOne by clicking here
DigiOne review by
The Hans Beekhuyzen Channel"
Parts supplied allo Digione
Module provided with spacers
You will find your Digione a set of spacers and screws M2.5 x 5mm in black light plastic. These elements allow a clean installation on SBC
Connectors
InputRaspberry Pi GPIO
Outputs1x BNC
1x RCA Coaxial
Components
Régulators10x LDO
Filters12x LPF
DC/DC converter
Digital Galvanic Isolator-
WM8805 Chip-
Buffers-
OscillatorsNDK
Jitter0.6ps
Noise level50uV
Dimensions65x55mm
Spacing57x48mm
InputGPIO
OutputBNC
OutputCoaxial SPDIF
DAC / ADC ChipWM8805
Max sampling rate192kHz
Interface chipWM8805
17 reviews
Allo Digione
Bona millora sobre Raspberry PI 4, so més net i sensació d'amplitud sonora millorada. En tot cas, veient el que es paga per un streamer és una compra molt assumible.
L'enviament va trigar 5 dies en arribar a casa.
Tot correcte,
This review has been posted for ALLO DIGIONE Raspberry Pi 2 / 3 / 4 Digital Interface SPDIF
extraordinaire carte son
superbe carte avec une sonorité époustouflante.
livraison super rapide.Je recommande+++
Pour ne plus utiliser l'usb du dac Khadas
L'interface digitale Allo DigiOne m'a permis d'envoyer directement le signal numérique vers l'entrée RCA de mon dac Khadas sans passer par l'entrée usb qui n'est plus utilisée.
Mon dac Khadas a sa propre alimentation externe, une allo (Référence : 11638), raccordée aux pins 1 (+) et 21 (-).
Une façon élégante et économique d'enterrer la polémique sur la dégradation de la qualité sonore si on passe par l'usb.
Dans Volumio il faut sélectionner I2S et Digione dans les paramètres de lecture, il faut aussi savoir que la commande de volume ne sera plus opérationnelle dans son interface.
Very good
Allo DigiOne - good, but that's it
Allo DigiOne was easy to install, immediately recognized in PiCorePlayer, and functions well with the Rpi 3B+.
Has an always-on bright green LED that can be annoying, covered mine with some black tape on the case I ordered (case had air vents it shone through).
Sound quality is good, no noise or jitter audible to me (using digital interlink to a DAC to a tube amp and the ~11 Euro Allo switching PSU).
At this price/performance, I can't justify getting the way more expensive Signature HAT in my upper mid-fi setup.
