ST6000 DAC ES9023x4 HDMI 24Bit / 192kHz 7.1CH for Raspberry Pi
ST6000 DAC ES9023x4 HDMI I2S 24Bit / 192kHz 7.1CH for Raspberry Pi
30%
Reduced price!
Reference : 11849
Limited special offer
65,83 €
-30%
46,08 €tax excl.
Including 0,04 € for green tax
This product is no longer in stock
Discover this exceptional DAC ST6000, equipped with ESS Saber ES9023 chips that can decode signals up to 24Bit / 192kHz. The unique feature of this DAC is its ability to be driven by Raspberry Pi SANS driver,directly via the HDMI port, and to be compatible Home Cinema 7.1CH.
This digital-to-analog converter with unprecedented functions is ideal for transforming your Raspberry Pi 3 / Pi 2 into a true home theater player.
Equipped with 4 ESS SABER ES9023 chips, 4 Ultra Low Jitter clocks, and 4 3.5mm Jacks, this DAC 7.1Ch will offer you a musical, dynamic and rich in micro details.
Intended for the many open source software solutions dedicated to audio playback, it allows a simpler implementation than ever for an incomparable result and very high performance.
The ideal power supply for this ES9023 DAC is available as accessories: Power adapter Power supply 100-240V to 5.1V 4A.
Specifications:
  • Home Theater Compatible: 7.1 channels
  • 4x DAC ESS Saber ES9023: Each DAC uses its own ultra low jitter clock
  • Supported Sampling Rates: Up to 24Bit / 192kHz
  • Signal to noise ratio: 112dB
  • Level of spellie: 2V RMS
  • Texas Instruments Ultra-Low Voltage Regulator
  • Inputs: HDMI / GPIO Raspberry Pi
  • Outputs: 4x Jack 3.5mm / HDMI / Optical toslink
  • DC input on 5.5 / 2.1 mm Jack for power supply
  • Audio formats supported HDMI: LPCM 2 / 5.1 / 7.1CH / Dolby Digital 2 ~ 5.1CH / DTS 2 ~ 5.1CH / Dolby Digital Plus / Dolby TrueHD // Li>
  • Supported Audio Formats Optical: LPCM 2CH / Dolby Digital 2 ~ 5.1CH / DTS 2 ~ 5.1CH
  • Fed the Raspberry Pi
Compatibilities Open Source solutions:
  • OSMC: Stereo 2.0 / 5.1Ch Surround / 7.1Ch Surround
  • Openelec: Stereo 2.0 / 5.1Ch Surround / 7.1Ch Surround
  • Moode Audio: Stereo 2.0
  • Raspbian: Stereo 2.0
  • Rune Audio: Stereo 2.0
  • PiCorePlayer: Stereo 2.0
  • Max2Play: Stereo 2.0
Dimensions / Packaging:
  • Supplied in 5V / 4A: power supply available in accessories
  • Supplied with 8 screws and 4 spacers M2.5 for fixing it on the Raspberry Pi (HAT format), as well as the gold-plated HDMI offset
  • Mounting Hole Distance (HAT): 50x58mm
  • PCB Dimensions: 122x90x90mm
  • Weight: 76g
  • Color PCB: black
DAC 7.1Ch pour Raspberry
InputI2S
Components / ChipES9023
ConnectionTo connect
Channel8 channels
Colissimo - TNT - SoColissimo
