Module DAC ES9038Q2M Bluetooth 5.0 aptX 24bit 384kHz
This small Bluetooth receiver / DAC module integrates an ES9038Q2M D/A chip and a Qualcomm QCC3003 Bluetooth receiver chip. It supports up to 24bit 384kHz PCM streams. Bluetooth 5.0 functionality is compatible with the aptX codec. High-performance and practical, it lets you integrate wireless reception capability with a quality DAC into your DIY audiophile project.
4.0 / 5
Reference : 18366
25,90 €tax incl.
21,58 € tax excl.
Shipping date: 17-06-2025.
DAC - Bluetooth 5.0 Module
Bluetooth 5.0 Receiver Module QCC3003 AptX / DAC ES9038Q2M 24bit 384kHz
Module DAC ES9038Q2M 24bit 384kHz Bluetooth 5.0 QCC3003 AptX
This small Bluetooth receiver / DAC module integrates an ES9038Q2M D/A chip and a Qualcomm QCC3003 Bluetooth receiver chip. It supports up to 24bit 384kHz PCM streams. Bluetooth 5.0 functionality is compatible with the aptX codec. High-performance and practical, it lets you integrate wireless reception capability with a quality DAC into your DIY audiophile project. This PCB also incorporates a FTC 11F04E microcontroller to manage the I/Os, as well as 3 LEDs indicating the input sources and a button for selecting them.
Inputs include coaxial, optical and Bluetooth reception. Outputs include an RCA stereo output and a 3.5mm jack. Power is supplied via a USB-C 5V connector.
How to use this module
To select an input source, simply press the button on the front of the PCB. The three LEDs will then indicate the selected source. To use Bluetooth, simply select it as a source and pair your emitter device using password 0123.
The default source is Bluetooth. However, a source can be memorized to become the default source.
The Bluetooth Receiver / DAC ES9038Q2M module
1USB-C power input
2Coaxial SPDIF input
3Right channel RCA output
4Left channel RCA output
5Toslink optical input
6DAC chip ES9038Q2M
7Source selection button
83.5mm jack output
9Toslink optical LED indicator
10Coaxial SPDIF LED indicator
11Bluetooth LED indicator
12Bluetooth chipset : Qualcomm QCC3003 / Antenna
Product typeBluetooth receiver module / DAC
InputsBluetooth 5.0
1x SPDIF Coaxial
1x Optical Toslink
Outputs1x RCA stereo
1x 3.5mm jack
DAC chipES9038Q2M
Supported sample ratesSPDIF coaxial: 24bit 384kHz
Optical Toslink: 24bit 192kHz
Bluetooth chipQCC3003
Supported transmission codecsSBC, AAC, aptX
Power supply5V via USB-C
Dimensions80 x 62mm
Weight28g
Package1x Bluetooth 5.0 Receiver Module QCC3003 AptX / DAC ES9038Q2M 24bit 384kHz
OutputJack 3.5mm
DAC / ADC ChipES9038Q2M
Max sampling rate384kHz
Ca fait le job - Portée Bluetooth réduit.
Je l'utilise en entrée Optique pour mon ampli. Je l'alimente avec simple alimentation USB-C. Je ne trouve pas que la qualité soit mieux que celle de mon DAC à base de 9018K2M.
La portée du bluetooth est très réduite et la puce qui possède l'antenne est soudée au PCB. Il me semble impossible de l'utiliser avec un boitier métal. Pas d'antenne externe.
Pour le prix, c'est un produit très convenable !
This review has been posted for Module DAC ES9038Q2M Bluetooth 5.0 aptX 24bit 384kHz
This small Bluetooth receiver / DAC module integrates an ES9038Q2M D/A chip and a Qualcomm QCC3003 Bluetooth receiver chip. It supports up to 24bit...
