AUDIO-GD NFB-11.38 PERFORMANCE EDITION DAC ES9038PRO / Pre / Headphone amplifier DSD 32bit / 384kHz Accusilicon
The Audio-GD NFB returns with several notable evolutions. Its digital / analog conversion stage works now thanks to a ES9038Pro chip, which is close to the top of decoding technology for a compact and very efficient DAC.
4.7 / 5
By buying this product you get 48 loyalty points
Reference : 12856
489,00 €tax incl.
407,50 € tax excl.
Shipping date: 16-05-2025.
AUDIO-GD NFB-11.38 2019 - Performance edition - Femtosecond Accusilicon 318B clock
DAC / preamplifier / headphone amplifier
Audio GD NFB November 38
Version 2019 -  Performance Edition
This is 2019 version of NFB-1138 It is equiped with the last Accusilicon 318B oscillators to upgrade the DAC precision even further than with TCXO clocks.
In its 11.38 version, the NFB receives a Femto crystal. The global system stability is thereby increased and it provides access to ever more impressive levels of accuracy in terms of details of the soundstage, stereo depth  and frequency balance.
More than ever, the NFB is a very versatile tool, which carries with precision and accuracy the functions of DAC, preamp and headphone amplifier. To complete the experience, it enjoys a double stage power-supply, multiple selectable digital filters and a MCU controller.
SABRE ES9038Pro
The NFB-11.38 embeds now a DAC ESS ES9038Pro for converting the digital signals into analog. This allows a sampling rate support output up to 32bit / 384kHz and a high-end S/N ratio of 120dB.
This change in chip also supports a broad dynamic range, capable of reaching 140dB.
ess 9038 pro
Accusilicon oscillator
Crystal Audio-gd accusilicon audiphonics
Using a crystal Femto significantly reduces jitter (ultra-low jitter) and will significantly prevent the inaccuracies and parasites at the critical time of decoding by the ES9038 SABRE chip.
High stability in processing data that promotes the capabilities of the NFB 11.38 and allows it to achieve impressive sound clarity levels.
CHA & Non-Feedback
discrete amplification stage
In addition to supporting the DSD / DXD and sample rates up to 32bit / 384kHz, the 11.38 NFB takes advantage of the technology NFB (No-Feedback) developed by Audio-GD on its ACSS stage.
It operates as a discrete preamp stage that is totally free of operational amplifiers and other gain stage. With this construction, the signal is processed with high purity without unnecessary coloring of the sound, making it an element of choice for High Fidelity usage.
384 Combo USB Amanero
Output AudioLR nfb11.38
Equipped with a USB interface Amanero Combo 384 rather than USB32, it offers both optimum performance and compatibility. It therefore supports sample rates up to 32bit / 384kHz and the DXD, and DSD64 DSD128 (DSD256 DSD512 and Windows) .Its design allows it to enjoy a very low jitter.
Warning, a driver is required to run Windows. Linux and MacOS operating systems will be automatically recognized.
S / N ratio120 dB
Output LevelHeadphone Output: 10V RMS
Variable output mode: 5V (max)
Fashion fixed output: 2.5V Rms
output (headphone)3500mW / 25 ohms
1800mW / 50 ohms
900mW / 100 ohms
300mW / 300 ohms
150mW / 600 ohms
output impedance2 ohm / Headphone
2 ohm / output DAC
Support OSWindows, Mac, Linux
supported Fréq.EchantillonnageUSB: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz, 352.8kHz, 384kHz
Coaxial: 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4, 192kHz
Optical: 44.1kHz, 48kHz, 88.2kHz, 96kHz
Frequency band20Hz-20KHz (-0.2 dB)
3Hz-350kHz (analog portion)
Food220-240V AC 50/60 Hz
Power consumption12W
Total weight2.2kg
Dimensions180x220x55
HousingAluminum with feet
Accessoriesx1 Power Cable
USB cable x1
To the DAC NFB-11 variable output position or fixed output (volume)
Configuration Mode fixed volume / variable volume jumper
By default, the NFB-11 is configured as a variable volume (adjustable volume). The apparatus is nevertheless designed to pass mode fixed volume. To do this, simply change the position of selection jumper. The user can thus variable output between a helmet and DAC (DAC + preamp) and a fixed output.
Warning do not position the NFB-11 in a fixed position when you connect it to a power amplifier with no volume control.
The headphone output is still affected by the volume control.
Setting up filters
warm jumpers filters
Particularly useful for use with headphones to the sound very clear, two other jumper used to make the sound warmer. If both are turned on, the NFB-11 will sound less bright and less aggressive in blast treble.
digital filters
Specific filters DSD / PCM are accessible in the same way. Simply connect jumpers in the correct sequence to activate the filter you like.
Here is the mapping configuration based on the desired filters;
PCM: FIR0, FIR1, FIR2
Fast roll-off, Linear:Push Into Push Into Push Into
Slow roll-off, Linear:Push Into Into Push Pull Off
Fast roll-off, Minimum:Push Into Push Pull Off Into
Slow roll-off, Minimum:Push Pull Off Into Pull Off
Fast roll-off, Hybrid:Pull Off Off Into Push Pull
Brickwall filter:Pull Off Pull Off Pull Off
OutputACSS
DAC / ADC ChipES9038PRO
Max sampling rateDSD512
Max sampling rate384kHz
ClassN/A
7 reviews
Un Monster truck !
Comment définir ce beau camion ?!
C'est du très lourd. Tu branches ton casque et il envoie toute la réserve d'essence et de nitro ^^
Il est très simple à installer avec toute fois les driver USB à installer sur Windows.
L'écoute est impressionnante de détails.
À acheter sans sourciller.
This review has been posted for AUDIO-GD NFB-11.38 PERFORMANCE EDITION DAC ES9038PRO / Pre / Headphone amplifier DSD 32bit / 384kHz Accusilicon
Jouissif !
Déjà possesseur de plusieurs appareils AUDIO-GD, dont un NFB11 2015 (es9018) qui sonnait déjà très bien, je ne partais pas en terre inconnue à la commande de cette version. On passe bien dans autre monde avec cette nouvelle itération à base de 9038, meilleure définition, plus de finesse, un grave très articulé et abyssale, et pas la moindre agressivité ! Comme dans l'avis de Jean-David, le son est "live". Sur des enregistrement de qualité en live justement (Habouk trio, Musica Nuda, Jordi Savall,...) je ferme les yeux et j'oublie complètement le matériel ! Le but est atteint, non ?
Superbe!
Ce NFB11.38 est fabuleux : image précise et dynamique, son charnu, basses profondes, aigus ciselés et médium parfait. Je lui donne la note la plus élevée.
plutôt déçu
Je me suis rabattu sur cet appareil suite à l'indisponibilité d'un lecteur réseau qui était mon 1er choix. Assez déçu par la qualité du son au vu de la technologie déployée.
Cet appareil ne m'a pas fait vibrer. L'écoute avec mon casque Beyer DT 1990 pro manquait de dynamique et de punch. Ecoute peu roborative, scène sonore un peu "floue".
Audiophonics ne m'a fait aucune difficulté pour échanger finalement cet appareil contre un lecteur réseau Matrix Element I dont je suis très satisfait et dont la partie ampli-casque, excellente, me convient bien mieux que l'Audio-GD.
Audio GD NFB 1138 Performance Edition
Avant de commander ce combo, je me suis documenté pendant deux mois. J'ai abouti à une "short list" de 10 appareils, et c'est là que David d'Audiophonics m'a considérablement aidé à faire le choix définitif.
Ce combo a un prix qui pourrait aisément être au double sinon au triple si l'on fait un comparatif avec le matériels existants du marché ainsi qu'un bilan performances/prix.
J'ai perso un casque Grado PS500e, 32 Ohms qui détaille la musique, large bande 19htz/29 Khz, scène sonore très large et précise. Je voulais un dAC au top et un ampli digne de ce nom pour ne rien perdre des qualités de mon casque. Je suis comblé, je ne m'attendais pas à une écoute aussi performante, détaillée et coulante à la fois. Quant au préampli, je le pousse en général au quart de ses possibilités et ça cartonne ! Si vous privilégiez l'écoute à l'esthétique, foncez, vous ne le regretterez pas. Livraison en 3 jours parfaitement protégé. Que désirer de plus ?
The Audio-GD NFB returns with several notable evolutions. Its digital / analog conversion stage works now thanks to...
