By buying this product you get 363 loyalty points
R2R DAC Balanced Class A Headphone Amplifier Preamplifier 32bit 384kHz DSD512 Black
A new creation from Audio-GD, the R-27HE is a balanced R2R DAC ladder with a built-in headphone amplifier and ACSS preamplifier. This improved version of the R-27 now features a regenerative power supply capable of providing an extremely clean electrical signal to the audio circuits. The entire design benefits from great attention to detail and component selection to provide the best possible sonic performance. The R-27HE also features a FIFO buffer with an optimized FPGA and a highly efficient reclocking system.
Key features :
The stage in charge of the analog/digital conversion is based on 4 integrated shielded DA-7 V2 modules. These modules directly interpret each bit of the digital signals to reconstruct the analog signal. Each module performs its task by acting on a network of resistors with a given value (R) and its double (2R), without going through an oversampling phase. This particular construction allows to decode digital signals with a quasi insensitivity to jitter while avoiding any possibility of recovering clock noises in the output signal.
Each channel is decoded separately by its own set of modules to achieve optimal crosstalk. To take this a step further, each channel of the stereo system uses its own linear power supply to minimize the amount of noise that can affect the soundstage and the stereo.
The module sets are supported by an FPGA. This one is in charge of the synchronization of the audio signals and the rejection of the jitter. It allows to offer a more precise and transparent sound restitution, while drastically reducing noise. 3 Accusilicon clocks are also integrated, allowing once again to reduce jitter to a minimum thanks to an optimal synchronization of the signals.
In order to eliminate the influence of jitter on the incoming signal, the R-27HE uses an asynchronous clock system. The asynchronous clocking system first reads and stores a large amount of data in RAM, while eliminating the clock from the source signal. This data is then passed to the integrated Accusilicon high-performance clocks, and all data and clock signals are then managed by the FPGA. This special design significantly reduces the final jitter level for a very natural, faithful and accurate sound reproduction.
The R-27HE incorporates a true balanced architecture with ACSS technology for its headphone amplifier and preamp stages. These use a single, very low distortion ACSS gain stage to minimize the signal path and maintain the most neutral sound possible. This gain stage and the associated output stage operate in pure Class A. ACSS is a non-feedback technology using only discrete amplifiers within a balanced structure.
A regenerative power supply is capable of filtering out interference on the power line to provide the purest possible power to the audio circuits. In this design, AC power is converted to DC power by the input transformer and then supplied to the regenerative waveform generator via a Class A parallel stabilized power supply. A set of regenerative waveform generators produces a 50Hz sine wave with very low distortion. After passing through a balanced gain stage, three regenerative output transformers produce a pure voltage with stable amplitude and frequency. Two sets of parallel regulated Class A power supplies finally provide independent power supply to the analog output stages and the digital audio circuits.
Here again, the R-27HE departs from convention by using a volume control based on I/V conversion at the output of the ACSS amplifier. This non-destructive method maintains a flat frequency response and does not lose any detail. To achieve this, the Audio-GD R-27HE uses relays and resistors with a tolerance of only 0.05%, ensuring a high degree of precision in the setting and perfect channel balance.
Product type | R2R DAC Headphone amplifier Preamplifier |
Inputs | 1x AES/EBU 1x BNC 1x Coaxial 1x Optical Toslink 1x I2S lVDS via HDMI 1x USB-B 1x Stereo XLR |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo XLR 1x ACSS 1x Single-ended Jack 6.35mm headphone output 1x Balanced XLR 4 pins headphone output |
Supported sampling rates | USB / I2S : PCM up to 32bit 384kHz, Native DSD up to DSD512 AES / Coaxial : PCM up to 24bit 192kHz Optical : PCM up to 24bit 96kHz |
SNR | > 120dB |
THD+N | < 0.03% |
Gain | Low : +13dB High : +26dB |
Channels imbalance | < 0.05dB |
Frequency response | 20Hz - 20kHz (< -0.25dB) 20Hz - 150kHz (< -3dB) |
Output level | Variable preamplifier output : XLR : 20V max / RCA : 10V max Fixed DAC output : XLR : 2-5V / RCA : 1-2.5V |
Balanced headphone output power | 15W @ 25Ω 10W @ 40Ω 4W @ 100Ω 1350mW @ 300Ω |
Single-ended headphone output power | 4W @ 25Ω 2500mW @ 40Ω 1000mW @ 100Ω 350mW @ 300Ω |
Digital input sensitivity | Coaxial 75Ω : 0.4-1Vp-p Optical : 19dBm |
XLR input impedance | 94kΩ |
USB Compatibility | Windows, OSX, Linux, ISO |
Supply voltage | 220-240VAC 50/60Hz |
Consumption | 53W |
Dimensions | 430 x 480 x 123mm |
Color | Black |
Package | 1x Audio-GD R-27HE 1x AC Power cable 1x USB Cable 1x Metal remote control |
Input | Optical |
Input | BNC |
Input | USB |
Input | SPDIF |
Input | I2S via HDMI |
Input | AES/EBU |
Input | XLR |
Output | ACSS |
Output | RCA |
Output | Jack 6.35mm |
Output | XLR |
Max sampling rate | 384kHz |
Max sampling rate | DSD512 |
Color | Black |
Class | Class A / AB |
Networking | No |
Remote Control | Yes |
