AUNE X1S GT DAC Headphone Amplifier Balanced 32bit 768kHz DSD512
The Aune X1s GT is an elegant and powerful desktop DAC and amplifier, belonging to the 8th generation X1. Its optimized and neat architecture allows it to support high resolution files, up to PCM 32bit 768kHz and DSD512 via the USB input or 24bit 192kHz and DSD128 from the Coaxial and Optical inputs.
By buying this product you get 31 loyalty points
Reference : 15641
319,00 €tax incl.
265,83 € tax excl.
Shipping date: 19-06-2025.
Aune X1s GT
Aune X1s GT DAC Amplificateur Casque Symétrique 32bit 768kHz DSD512
Versatile, it has a complete connectic with USB-B, Optical Toslink and Coaxial inputs, as well as a BNC input to associate an external 10MHz clock to the X1s GT. On the output side, we can count on stereo RCA line and pre-out, as well as two headphone outputs in single-ended Jack 6.35mm and balanced Jack 4.4mm format.
The amplifier stage of the Aune X1s GT uses four discrete amplifiers with no less than 96 bipolar transistors in total.
The Aune X1s GT also offers features such as clock synchronization and PLL technology as well as seven filters to tailor the unit's output to your listening style.
Product typeDAC
Headphone amplifier
USB chipXMOS
Inputs1x USB-B
1x Optical Toslink
1x Coaxial
1x BNC for 10MHz clock
Outputs1x Line stereo RCA
1x Pre-out stereo RCA
1x Single-ended Jack 6.35mm headphone output
1x Balanced Jack 4.4mm headphone output
Supported sampling ratesUSB : PCM up to 32bit 768kHz
DSD up to DSD512
Coaxial / Optical : PCM up to 24bit 192kHz, DSD up to DSD128
Power supply suppliedMeanwell 9V 2.55A (5.5 / 2.1mm Jack)
InputBNC
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipBurr Brown
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
Remote ControlN/A
The Aune X1s GT is an elegant and powerful desktop DAC and amplifier, belonging to the 8th generation X1. Its optimized and neat architecture...
