AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black
17%
The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable AOP as well as the seven available filters, while adding a preamplified TRS balanced output. In addition, this BT version also benefits from Bluetooth connectivity with support for the high-resolution transmission codecs aptX HD and LDAC.
4.3 / 5
Reduced price!
Reference : 16398
Limited special offer
309,00 €tax incl.
-17%
256,47 €tax incl.
213,73 € tax excl.
Aune X8 XVIII BT Magic DAC
Aune X8 XVIII BT Magic DAC FPGA Bluetooth aptX HD LDAC 32bit 768kHz DSD512
Aune X8 XVIII BT MAGIC: DAC ES9038Q2M
The X8 XVIII allows the decoding of high resolution audio streams up to PCM 32bit 768kHz and DSD512. Using an ESS ES9038Q2M DAC chip, the X8 XVIII offers a precise, dynamic and detailed sound reproduction.
Aune X8 XVIII BT MAGIC:TRS balanced output
In addition to its USB, coaxial and optical inputs and its RCA pre-out and line outputs, the X8 XVIII is now equipped with a balanced preamplified output in 6.35mm TRS format.
Aune X8 XVIII BT MAGIC:Interchangeable AOP
The Aune X8 XVIII takes the concept of the interchangeable AOP. This one is indeed mounted on DIP8 support and accessible under the device. You just have to replace it by another model to adapt the sound reproduction of the DAC according to your audio system and your listening.
Aune X8 XVIII BT MAGIC:Seven available filters
The Aune X8 XVIII provides seven filters. Just like the interchangeable AOP, these allow you to adjust the sound signature of the device according to your desires.
1Selection button
2LED indicator
3Volume button
4Coaxial input
5Bluetooth antenna
6Power switch
7Preamp outputs
8Line out
9Optical input
10USB-B Input
11Powre connector
Product typeDAC
DAC chipESS ES9038Q2M
Inputs1x Coaxial
1x Optical
1x USB-B
Bluetooth
Outputs1x Stereo RCA (Pre-Out)
1x Dual Jack 6.35mm TRS (Pre-Out)
1x Stereo RCA (Line out)
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Coaxial : PCM up to 24bit 384kHz, DSD DoP up to DoP128
Optique : PCM up to 24bit 192kHz, DSD DoP up to DoP64
Output level2Vrms
Frequency response20Hz ~ 20kHz ±0.5dB
SNR121dB
THD+N (1kHz)0.00027%
PackageAune X8 XVIII
1x Power adapter
1x USB Cable
1x Bluetooth antenna
OutputJack 6.35mm
DAC / ADC ChipES9038Q2M
Max sampling rateDSD512
Max sampling rate768kHz
Remote ControlN/A
3 reviews
DAC with sparkos ss2590
This dac for the price is wonderful, I bought it and directly installed the operational sparkos SS2590 Pro. The sound is simply perfect, I couldn't imagine it better. Airy, clear, musical, with an impressive dynamics. I recommend 100% the update with SS2590 Pro. Warning, you need to buy a small elevalor for the chip, otherwise it touches the case, and then put some higher feet.
This review has been posted for AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black
Standart package *** stars worth
I wrote a review for ASR. In short, you should know:
Only one extra Op-Ams comes with the set.
All the extra Op-Amps offered by Aune are no better than a cheap DAC on the market. The sound starts to normalize around OPA627, which can be purchased separately, and because of which you will not be able to close the lid of the device. The optical port does not click into place. The potentiometer has difficulty separating the channels. A POP sound will be heard when laying in/out. Only with Sparkos SS3602 will you have a real benefit. You can initially buy the cheap BB OPA627 and upgrade over time, or upgrade immediately if funds allow and the system is ready for it.
A hi fi device by all means
I have it only a week now but from the first moment it gave me the confidence and pleasure that only real hi fi devices do.Always on it runs cool, every input/ output works perfectly, usb driver a breeze, sound really better than my Burson conductor 3 reff wich cost me more than 4 times more and now returned to its box as a veteran (a war casualty.)
The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the...
