USB DAC Preamplifier Headphone Amplifier PCM5242 24bit 192khz
CYP offers with the DCT-24 a versatile device, acting as a USB DAC, preamplifier and headphone amplifier, at an affordable price. Efficient, it supports PCM audio streams up to 24bit 192kHz on its USB-B input thanks to its TI PCM5242 digital-to-analog conversion chip. Versatile, the DCT-24 offers 3.5mm jack, stereo RCA, USB-B and RS-232 inputs in 3.5mm jack format that can be connected to a computer. For its outputs, there is a stereo RCA line output and a 6.35mm jack headphone output.
The DCT-24 is extremely simple to use, with only two buttons on the front panel, allowing you to select a source and adjust the volume level. All components are integrated in a sturdy black aluminium housing, sober and elegant.
| Specifications | |
| Product type | DAC Préamplifier Headphone amplifier |
| Inputs | 1x Jack 3.5mm 1x Stereo RCA 1x USB-B 1x Jack 3.5mm RS-232 |
| Outputs | 1x Stereo RCA 1x Jack 6.35mm headphone output |
| DAC Chip | TI PCM5242 |
| Audio input/output format | LPCM 2 channel |
| Stereo input/output level | 2Vrms +/-10% |
| Supported sampling rate | Up to 24bit 192kHz |
| THD+N | < 0.01% |
| SNR | > 80dB |
| Crosstalk | < -70dB |
| ESD Protection | +/-8kV (air-gap discharge) +/-4kV (contact discharge) |
| General | |
| Power supply | 5VDC 3A (power supply included) |
| Consumption | 8.5W |
| Dimensions | 145 x 128 x 30mm |
| Weight | 375g |
| Case material | Aluminium |
| Color | Black |
| Operating temperature range | 0°C - 40°C |
| Storage temperature range | -20°C - 60°C |
| Input | Jack 3.5mm |
| Input | RCA |
| Output | RCA |
| Output | Jack 6.35mm |
| DAC / ADC Chip | PCM5242 |
| Max sampling rate | 192kHz |
| Color | Black |
| Networking | No |
| Remote Control | No |
