DAC PCM5100 DAC Preamplifier
This small, compact Hi-Fi device is extremely versatile, as it acts as a DAC, preamplifier and headphone amplifier. It also features a source selector potentiometer. It integrates components such as a PCM5100 DAC chip, an MS8416 digital audio interface and OPA4558 AOPs.
POINTS CLÉS :
  • DAC PCM51100
  • Digital interface MS8416
  • OPA4558
  • USB 48kHz
  • Optique 96kHz
Reference : 18508
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 13-05-2025.
DAC / Preamplifier DAC PCM51100 / Digital interface MS8416 / Headphone Amplifier / Source Selector
DAC PCM5100 / Preamplifier / Headphone Amplifier / Source Selector
This small, compact HiFi device is extremely versatile, as it acts as a DAC, preamplifier and headphone amplifier. It also features a source selector potentiometer. It incorporates components such as a PCM5100 DAC chip, an MS8416 digital audio interface and OPA4558 AOPs. These components enable it to support sampling rates of up to 48kHz via its USB input and 96kHz via its Toslink optical input. In addition to its two digital inputs, it has a stereo RCA input and two outputs: a stereo RCA line output and a headphone output on a 6.35mm jack connector. This Hi-Fi device is the ideal solution for centralizing several digital & analog sources and accessing them from a single circuit.
It is easily powered via a 5.5/2.1mm DC JACK connector on the rear panel. Simply supply it with 12V DC and it will operate normally.
Caution : no power supply is included with this module, you may find an appropriate SMPS here with the right DCjack connector
Volume control and inputs selector
Two potentiometers are located on the front panel. The first controls the volume, while the second selects the input source: USB, optical or auxiliary analog RCA input. Source selection is performed via an EC2-NU relay so that it's performed smoothly.
Source selection :
  • Input 1: USB (blue LED)
  • Input 2: Optical (green LED)
  • Input 3: RCA (red LED)
Potentiometers of the DAC PCM5100 / Preamplifier / Headphone Amplifier / Source Selector
Reliable components
This small DAC / source selector is characterized by a construction that respects High Fidelity standards. It features film resistors with ± 1% tolerance and Nikon 2200µF electrolytic capacitors dedicated to power supply filtering.
The PCB itself benefits from a double-sided copper foil structure 1.6mm thick.
Internal components of the DAC PCM5100
DAC PCM 51100 overview
1Stereo RCA line output
2 USB-B input
3Optical Toslink input
4Stereo RCA input
5DC 12V power supply on 5.5/2.1mm jack connector
Product typeDAC
Preamplifier
Headphone amplifier
Source selector
DAC chipPCM5100
Digital audio interfaceMS8416
AOPOPA4558
Inputs1x USB-B 2.0 input
1x Toslink optical input
1x Stereo RCA input
Outputs1x Stereo RCA output
1x 6.35mm headphone output
Supported sample ratesUSB : 48kHz Max
Optical : 96kHz Max
LED indicatorSelected input
Volume control
Dimensions150 x 92 x 40mm
Weight390g
Package1x DAC PCM5100 / Preamplifier / Headphone amplifier / Source selector
OutputJack 6.35mm
DAC / ADC ChipPCM5100
Max sampling rate96kHz
Max sampling rate48kHz
ClassN/A
This small, compact Hi-Fi device is extremely versatile, as it acts as a DAC, preamplifier and headphone amplifier. It also features a source...
