Dac Z6 reçu rapidement(comme toujours
DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
The EverSolo DAC-Z6 is a powerful DAC based on a neat technical structure. It embeds high-end components with notably two ESS ES9068AS digital/analog conversion chips and a XMOS XU316 USB interface allowing it to support high resolution audio streams and to provide a clear and detailed sound reproduction. The DAC-Z8 also offers a wide range of features making it a versatile and efficient device.
The heart of the DAC-Z6, its digital-to-analog conversion stage, is equipped with a pair of ESS ES9068AS chips. These ensure low distortion and noise for a seamless high-fidelity music experience. This balanced structure also greatly reduces interference that could alter the integrity of the audio signal. In addition, the DAC-Z6's audio circuitry is specifically calibrated to deliver its full potential.
The USB input of the DAC-Z6 is combined with an XMOS XU316 interface, which is able to process audio data quickly and efficiently for optimal signal transmission. This chip also supports high-resolution streams up to PCM 32bit 768kHz and DSD512 Native, as well as MQA files.
The EverSolo DAC-Z6 supports the decoding of MQA (Master Quality Authenticated) files from its USB, Toslink optical and coaxial inputs. This format allows to enjoy a sound quality as close as possible to the original studio recording.
The DAC-Z6 is equipped with two very high precision clocks on the frequencies 45.1584MHz and 49.152MHz. These allow you to enjoy a high quality decoding, ensuring a very low jitter for a detailed and accurate sound.
The DAC-Z6's analog audio circuitry is fully balanced and uses multiple OPAs. The XLR, RCA and headphone outputs are all processed by a balanced differential amplifier circuit ensuring low noise and improved channel separation. The high-fidelity preamplifier circuitry provides precise and efficient volume control.
In addition to full connectivity, the DAC-Z6 features a Qualcomm QCC5125 Bluetooth 5.0 receiver, making it possible to stream music remotely from a smartphone or tablet, for example, while supporting the high-resolution aptX HD and LDAC transmission codecs for high-quality wireless playback.
The EverSolo DAC-Z6 provides 3 sets of digital filters, each with different sound characteristics. These allow you to adapt the sound reproduction of the device according to your listening preferences and your audio system.
A low-noise power supply stage and capacitor filter have been specially optimized for the DAC-Z6. They provide a clean, interference-free electrical signal to all of the unit's audio circuits for rich, accurate sound reproduction.
The DAC-Z6's headphone amplifier also performs very well and is capable of providing comfortable power to accompany headphones with impedance from 16 to 300Ω without difficulty. This one also has a two-step gain control to accommodate both demanding headphones and more sensitive earphones.
The front panel of the DAC-Z6 features a beautiful 3" color LCD screen. This one displays an ergonomic and intuitive interface allowing you to access all the functions and parameters of the DAC.
The DAC's multi-function knob can be used to control the volume level, navigate menus, select a source or output, change filters, change the display, etc. It allows full control of the device in a convenient way.
The EverSolo DAC-Z6 is dressed in a beautiful, sturdy aluminum chassis that has been precision-machined by CNC (numerical control). It offers a modern and sober design, allowing it to be easily integrated into any audio system.
| Specifications | |
| Product type | DAC |
| Inputs | Bluetooth 5.0 1* USB-B 1* USB-C 1* Optical Toslink 1* Coaxial |
| Outputs | 1* Balanced stereo XLR 1* Single-ended RCA 1* Jack 6.35mm headphone output |
| DAC chip | ES9068AS |
| USB interface | XMOS XU316 |
| OPA | 8* OPA1612 |
| Bluetooth receiver | Qualcomm QCC5125 |
| Supported sampling rates | USB : PCM up to 32bit 768kHz, Native DSD up to DSD512, MQA Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64, MQA |
| Supported Bluetooth codecs | SBC AAC aptX aptX LL aptX HD LDAC |
| Screen | LCD 3" |
| Control app | |
| Recommended headphone impedance | 16-300Ω |
| XLR output performances | |
| Output level | 4.1Vrms @ 0dBFS |
| THD+N (A-Weighted) | 0.000094% @ 1kHz (-120dB @ 1kHz) |
| THD+N (No-Weighted) | 0.000117% @ 1kHz (-118dB @ 1kHz) |
| Noise (No-Weighted) | < 3µVrms |
| SNR (No-Weighted) | 125dB @ 1kHz |
| Frequency response | 20Hz-20kHz (±0.15dB) |
| Crosstalk | -123dB @ 1kHz |
| Dynamic range (No-Weighted) | 125dB @ 1kHz |
| RCA output performances | |
| Output level | 2.1Vrms @ 0dBFS |
| THD+N (A-Weighted) | 0.000116% @ 1kHz (-118dB @ 1kHz) |
| THD+N (No-Weighted) | 0.000135% @ 1kHz (-117dB @ 1kHz) |
| Noise (No-Weighted) | < 2.5µVrms |
| SNR (No-Weighted) | 121dB @ 1kHz |
| Crosstalk | -118dB @ 1kHz |
| Dyanmic range (No-Weighted) | 121dB @ 1kHz |
| Headphone output performances (Low gain mode) | |
| Output level | 1.2Vrms @ 0dBFS |
| Output power | 45mW @ 32Ω |
| THD+N (A-Weighted) | 0.00028% @ 1kHz (-111dB @ 1kHz) |
| THD+N (No-Weighted) | 0.00031% @ 1kHz (-110dB @ 1kHz) |
| Noise (No-Weighted) | < 3.5µVrms |
| SNR (No-Weighted) | 114dB @ 1kHz |
| Dynamic range (No-Weighted) | 114dB @ 1kHz |
| Headphone output performances (High gain mode) | |
| Output level | 2.8Vrms @ 0dBFS |
| Output power | 26mW @ 300Ω |
| THD+N (A-Weighted) | 0.00014% @ 1kHz (-117dB @ 1kHz) |
| THD+N (No-Weighted) | 0.00016% @ 1kHz (-116dB @ 1kHz) |
| Dynamic range (No-Weighted) | 121dB @ 1kHz |
| General | |
| Supply voltage | 110~240VAC 50/60Hz |
| Consumption | 9W |
| Dimensions (L*P*H) | 270*187*50mm |
| Color | Silver |
| Package | 1* EverSolo DAC-Z6 1* Remote control 1* Power cable |
| Input | Bluetooth |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Output | XLR |
| Output | RCA |
| Output | Jack 6.35mm |
| DAC / ADC Chip | ES9038PRO |
| Max sampling rate | MQA |
| Color | Black |
| Networking | No |
| Remote Control | Yes |
Average votes 5.0 / 5 5 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
HERVE H.
Cedric J.
Cedric J.
Philippe s.
Bruno C.
