Connexion Bluetooth: j'ai tenté de connecter une tablette Samsung Tab Acvive 2: le DFAC n'est pas détecté (Samsung bloque certaines adresse MAC). Le i-Phone 13 détecte le DAC mais l'appairage échoue, sans doute pour la même raison.
The FiiO BR15 R2R is a DAC built around a discrete 24-bit R2R architecture. It uses a network of 192 precision resistors within a fully symmetrical circuit, relying on the latest generation Bluetooth 6.0 reception to extend this conversion rigour to high-definition wireless sources via aptX Lossless and LDAC protocols.
Designed for hi-fi systems seeking an analogue sound signature, it combines flexible power management with advanced customisation of processing via NOS/OS modes and 10-band equalisation. This technical versatility allows it to adapt to the specific acoustic characteristics of the installation, while maintaining modern control ergonomics via the dedicated control application for seamless integration into the system.
The receiver stage is built around the Qualcomm QCC5181 chip, implementing the Bluetooth 6.0 standard to ensure optimal connection stability and reduced latency via LE Audio compatibility. This technology platform supports the aptX Lossless codec, enabling lossless signal transmission to achieve CD-equivalent quality (16-bit/44.1 kHz) over a wireless connection. Beyond this high resolution, stream management extends to aptX Adaptive, aptX HD, LDAC and AAC protocols, ensuring comprehensive interoperability with all transmitter sources on the market while dynamically adapting the bit rate to transmission conditions.
The FiiO BR15 R2R is based on a 24-bit R2R converter designed around a network totalling 192 precision resistors, divided into four channels of 48 resistors each. This entirely discrete architecture ensures conversion without a traditional DAC chip and emphasises warmer sound reproduction. The device also offers a choice of NOS (Non-Oversampling) or OS (Oversampling) modes, allowing for either a more raw and natural sound or a more detailed and clinical one, using oversampling up to 384 kHz.
The entire audio chain, starting with the DAC, low-pass filter, gain control, and volume control, utilises fully symmetrical signal processing for excellent interference elimination, minimal distortion, and high dynamic range.
The electrical architecture of the BR15 R2R adopts a hybrid topology, natively integrating an internal switching power supply for immediate and autonomous mains operation. This configuration is complemented by a dedicated DC input, offering the user the option of bypassing the internal circuit in favour of an external linear power supply. This upgrade option further isolates sensitive components from parasitic switching noise, thereby reducing background noise and improving the overall dynamics of the converted signal.
The BR15 R2R offers comprehensive remote control, allowing it to be operated either via the supplied remote control or the FiiO app, providing direct access to essential functions without physical interaction with the device. This approach allows for precise adjustment of volume, inputs and operating modes, while maintaining continuity of use in fixed or remote configurations.
For its BR15 R2R, FiiO has developed a 10-band equaliser. This allows you to customise the frequency response with excellent precision, as well as export, import, share and save equalisation curves. Whether you choose to use the recommended settings or share your own settings online with other enthusiasts, it's easy to access them using either the FiiO Control app or the online version.
| Specifications | |
| Product type | DAC |
| Inputs | 1x Coaxial 1x Optical Toslink 1x USB-C Bluetooth |
| Outputs | 1x Stereo XLR 1x Stereo RCA 1x Coaxial 1x Optical Toslink |
| Microcontroller | ESP32-S3 |
| DAC | R2R 24bit |
| Supported sampling rates | USB : PCM up to 32bit 384kHz, DSD up to DSD256 Coaxial : PCM up to 24bit 192kHz, DSD64 Optique Toslink : PCM up to 24bit 96kHz, DSD up to DSD64 |
| USB interface | XMOS XU316 |
| Bluetooth chip | Qualcomm QCC5181 |
| Supported Bluetooth codecs | LC3 / SBC / AAC / aptX / aptX HD / aptX Adaptive / LDAC / aptX Lossless |
| Total harmonic distortion more noise (THD+N) | RCA : 0.017% XLR : 0.015% |
| Crosstalk | RCA : ≥110dB XLR : ≥112dB |
| Frequency response | 20Hz~65kHz (±2.9dB) |
| Signal-to-noise ratio (SNR) | RCA : ≥116dB XLR : ≥119dB |
| Noise floor | RCA : <3.3µV XLR : <5.1µV |
| Dynamic range | RCA : ≥110dB XLR : ≥112dB |
| Output level | RCA : 2.2Vrms XLR : 4.4Vrms |
| General | |
| Power supply voltage | AC : 100-240V ~50/60Hz DC : 5V ≥2A |
| Dimensions | 188 x 210 x 42mm |
| Weight | 760g |
| Color | Black |
| Package | 1x FiiO BR15 R2R 1x Remote control 1x Power cable 1x RCA cable |
| Input | Bluetooth |
| Input | USB |
| Input | Optical |
| Input | SPDIF |
| Output | RCA |
| Output | Coaxial SPDIF |
| Output | Optical Toslink |
| Output | XLR |
| DAC / ADC Chip | R2R LADDER DAC |
| Max sampling rate | 384kHz |
| Max sampling rate | DSD256 |
| Color | Black |
| Networking | No |
| Remote Control | Control app |
| Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
ERIC C.
ERIC C.
