FOSI AUDIO K5 PRO DAC Headphone Amplifier
With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC/headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into a desktop installation, although it can easily be integrated into a more conventional audio setup. Indeed, in addition to its headphone output, the K5 Pro has an RCA output, which can be connected to an amplifier or directly to active speakers. Furthermore, the USB-C input is a 2-in-1 socket that can receive data and power the K5 Pro at the same time.
4.5 / 5
Reference : 19225
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 28-05-2026.
FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit / 192kHz
FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit / 192kHz : Front view
With the K5 ProFosi Audio offers a compact, versatile and affordable DAC / headphone amplifier. With its microphone input on the front panel, the K5 Pro is designed to fit into a desktop installation, although it can easily be integrated into a more conventional audio setup. Indeed, in addition to its headphone output, the K5 Pro has an RCA output, which can be connected to an amplifier or directly to active speakers. Furthermore, the USB-C input is a 2-in-1 socket that can receive data and power the K5 Pro at the same time.
The K5 Pro's amplification stage incorporates a NE5532 OPA and is capable of developing a power of 1000mW at 16Ω and 80mW at 300Ω, while maintaining a harmonic distortion rate below 0.003%. Note that signal amplification also applies to the 3.5mm jack microphone input.
As far as digital/analog conversion is concerned, the K5 Pro accepts input sampling rates of up to 24bit 192kHz for optical and coaxial input, and 16bit 96kHz for USB-C input.
FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit / 192kHz : Front and rear panel
1Indicator light
23.5mm Jack headphone output
33.5mm Jack microphone input
4Bass control
5Treble control
6Mode selection / Volume control / Power button
7USB-C input / Power supply
8Optical input
9Coaxial input
10Right RCA output
11Left RCA output
Product typeDAC
Headphone amplifier
Inputs1x USB-C
1x Coaxial
1x Optical toslink
1x 3.5mm Jack for microphone
Outputs1x Stereo RCA
1x 3.5mm Jack for headphones
OPANE5532
Supported sampling ratesUSB-C : up to 24bit/96KHz
Coaxial / Optical : up to 24bit/192KHz
Headphone output power1000mW @16Ω
500mW @32Ω
300mW @64Ω
150mW @128Ω
80mW @300Ω
Signal-to-noise ratio (SNR)≥110dB
Total harmonic distortion (THD)<0.003%
Recommended headphone impedance16Ω - 300Ω
Power supplyUSB-C 5V
Dimensions112 x 95 x 30mm
ColorGrey
Weight251g
Package1x Fosi Audio K5 Pro
1x USB-C cable
1x Optical cable
1x Two-in-one headset adapter
InputJack 3.5mm
OutputJack 3.5mm
DAC / ADC ChipNC
Max sampling rate192kHz
ColorGray
ClassN/A
2 reviews
Très satisfait
Nouvelle TV, nouvelle connectique: pas de sortie audio analogique ni de prise casque. L’utilisation de ce petit appareil a réglé le problème. Le son passe par la sortie optique et je peux utiliser un casque ou la sortie analogique RCA pour alimenter mes enceintes via le petit amplificateur Fosi BT 20 A que j’utilisais sur mon ancienne télé.
À noter que le K5 est alimenté par une prise USB de la télé et qu’il est possible d’utiliser à la fois le casque ET les enceintes, bien que ça ne serve pas à grand chose.
Seul bémol, la LED bleue en façade du K5 est très lumineuse et je suis obligé de la cacher pour profiter pleinement de la somptueuse image de ma télé toute neuve.
This review has been posted for FOSI AUDIO K5 PRO DAC Headphone Amplifier NE5532 24bit 192kHz
Un dac fonctionnel et plein de ressource
Bonjour,
Un dac acheté il y a peu de temps pour remplacer le fait de me brancher en direct sur mon PC avec un casque HyperX Cloud Alpha filaire. J'ai gagné en équilibre avec des médiums mieux maitrisé. Le fait de gérer à la volé le grave au l'aigu un MUST. J'ai aussi plus de puissance et ça ne bave pas sur les graves.
J'ai aussi testé sur mon casque de salon beyerdynamic DT770 80ohms je suis surpris de ce produit je recommande.
With the K5 Pro, Fosi Audio offers a compact, versatile and affordable DAC/headphone amplifier. With its microphone input on the front panel, the...
