FURUTECH ADL GT40a Alpha DAC / ADC CS4270 Phono Preamp Headphone Amplifier 24bit/192kHz
This excellent DAC / ADC converter is the evolution of the GT40 from the famous FURUTECH brand. This time, the GT40a Alpha is equipped with new converters capable of 24bit 192kHz playback via USB-B Class 2.0, as well as 24bit 192kHz analog recording and digitalization. It's a three-in-one device fulfilling the functions of DAC/ADC, MM/MC phono preamplifier/recorder and headphone amplifier.
By buying this product you get 96 loyalty points
Reference : 10135
485,00 €tax incl.
404,17 € tax excl.
Shipping date: 01-05-2025.
 DAC / ADC CS4270 / Phono Preamp / Headphone Amplifier 24bit/192kHz
FURUTECH ADL GT40a Alpha DAC / ADC CS4270 Préampli Phono Amplificateur Casque 24bit/192kHz
This time, the GT40a Alpha is equipped with new converters capable of 24bit 192kHz playback via USB-B Class 2.0, as well as 24bit 192kHz analog recording and digitalization. In fact, it features a Cirrus Logic CS4270 DAC/ADC chip. It is thanks to this chip that it also converts analog signals to digital. The GT40a Alpha lets you record analog signals in high resolution or play digital files via a lot of streaming platform such as Deezer, Spotify, Youtube or Qobuz.
As a true audio multi-function device, it features an RIAA Phono preamplifier for turntables, as well as a Maxim MAX9722A headphone amplifier. The advantage here is that it can amplify signals from MM and MC vinyl turntables and digitize them via a computer.
For the GT40a's headphone amplifier stage, it has been upgraded compared to its ancestor the GT40 (higher current capacity): it can drive headphones from 16 to 300 ohms, and the line output level is now raised to 5Vrms to easily drive active loudspeakers or power supplies.
In terms of appearance and connectors, this is a top-of-the-range device, with gold-plated Teflon-insulated RCA connectors and a high-quality aluminum chassis.
All in all, the GT40a Alpha from the renowned Furutech brand is a three-in-one device, fulfilling the functions of DAC/ADC, phono preamplifier/recorder and headphone amplifier.
Product typeDAC/ADC
Phono preamplifier/recorder
Headphone amplifier
DAC/ADC chipCS4270
USB interfaceVT1736
USB transmission typeAsynchronous
Headphone amplification chipMaxim MAX9722A
OPA (DAC, ADC, Line In & Out)NJM5532
OPA (Phono)NJM2068
Phono compatibility MM and MC
Inputs1x Stereo RCA analog input (grounded)
1x USB-B digital input
Outputs1x Stereo RCA analog output
1x 6.35mm headphone output
Supported sample ratesUSB: 24bit, 32kHz / 44.1kHz / 48kHz / 88.2kHz / 96kHz / 186.4kHz / 192kHz
USB compatibilityWindows (avec driver)
Linux
Mac OS
Fréquency response20Hz ~ 20kHz ( +/- 0.5dB)
SNR>90dB (Sortie ligne)
Output level (Line)5Vrms
Input level (Line)Phono MC: 0.4mV
Phono MM: 4mV
Line: 2Vrms
Phono input impedancePhono MC : 10kΩ
Phono MC : 47kΩ
Phono gainPhono MC : 62.5dB
Phono MC : 48.5dB
Recommended headphone impedance16Ω-300Ω
Headphone output power94mW (16Ω)
110mW (32Ω)
98.6mW (56Ω
23mW (300Ω)
Power supply15V DC 0.8A (included)
Dimensions150 x 111 x 57mm
Weight650g
ColorSilver
Package1x FURUTECH ADL GT40a Alpha DAC / ADC / Phono Preamp / Headphone Amplifier
1x Mains cable
InputPhono
OutputUSB
OutputJack 6.35mm
DAC / ADC ChipCS4270
Max sampling rate192kHz
ColorSilver
4 reviews
Livraison rapide
Matériel de belle facture, pas encore mis en service.
Merci Audiophonics sérieux et efficace.
This review has been posted for FURUTECH ADL GT40a Alpha DAC / ADC CS4270 Phono Preamp Headphone Amplifier 24bit/192kHz
Livraison rapide
Merci à Audiophonics, sérieux et efficace.
"Tout en un"
J'utilise ce matériel pour numériser mes vinyles (éviter l'usure par de nombreuses écoutes). Avec Audacity sous windows 10, ce convertisseur est parfait et permet de générer des fichiers 24b/192khz. C'est le seul, à ma connaissance, qui fonctionne correctement sous windows 10, en ayant pris soin de suivre la note du constructeur pour installer les pilotes. La sortie casque est bonne et permet le monitoring. Je ne donnerai pas d'avis sur la qualité du préampli phono, même s'il me semble correct, j'utilise un préampli tubes de haut niveau qui met la barre un peu haut pour une comparaison.
C'est un matériel de bonne facture pour numériser des sources analogiques mais aussi un très bon DAC usb/préampli en sortie de mon ordinateur.
Audiophonics est toujours à l'heure, livraison sans défaut comme toujours.
"tout en un"
J'utilise ce DAC ADC pour numériser mes vinyles (les préserver de l'usure de nombreuses écoutes). Avec audacity,
This excellent DAC / ADC converter is the evolution of the GT40 from the famous FURUTECH brand. This time, the GT40a Alpha is equipped with new...
