FX-AUDIO DS07 Balanced DAC ES9068AS XMOS XU216 Bluetooth 5.1 QCC5125 LDAC 32bit 768kHz DSD512 MQA
FX-Audio unveils its DS07 balanced DAC, a compact, high-performance device with an original appearance. FX-Audio's DS07 is made from a complete range of audiophile components: an ES9068AS DAC chip, an XMOS XU-216 USB interface, a QCC5125 Bluetooth 5.1 receiver chip and no fewer than 5 OPA1612 AOPs. These components enable this FX-Audio DAC to achieve excellent measurement performance.
By buying this product you get 20 loyalty points
Reference : 18449
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 24-06-2025.
FX-AUDIO DS07
Balanced DAC ES9068AS XMOS XU216 Bluetooth 5.1 QCC5125 LDAC 32bit / 768kHz DSD512 MQA
FX-AUDIO DS07 Balanced DAC ES9068AS XMOS XU216 Bluetooth 5.1 QCC5125 LDAC 32bit / 768kHz DSD512 MQA
FX-Audio unveils its DS07 balanced DAC, a compact, high-performance device with an original appearance. FX-Audio's DS07 is made from a complete range of audiophile components: an ES9068AS DAC chip, an XMOS XU-216 USB interface, a QCC5125 Bluetooth 5.1 receiver chip and no fewer than 5 OPA1612 OPAs. These components enable this FX-Audio DAC to achieve excellent measurement performance. In addition, it boasts extensive connectivity, including a balanced stereo output on XLR connectors.
ESS ES9068AS DAC chip
The DS07 incorporates an ESS Technologies ES9068AS 32-bit stereo DAC chip. The latter is based on a HyperStream® II QUAD DAC™ architecture and enables the DS07 to support high-fidelity sampling rates up to PCM 32bit 768kHz, native DSD up to DSD512 and even MQA streams.
A second-generation XMOS XU-216 USB interface with USB-B input completes the DS07 circuit. It provides this DAC with a high-performance digital input.
Bluetooth 5.1 reception
FX-Audio has chosen to integrate a Qualcomm QCC5125 Bluetooth 5.1 receiver chip for wireless transmission with high-resolution audio codecs: SBC, AAC, aptX, aptX HD, aptX LL and LDAC.
Remote control and color LCD screen
A remote control offers an enhanced user experience. Among other things, it lets you control volume and EQ, or select the input source of the DAC DS07. A color LCD screen also displays playback information.
FX-Audio DS07 overview
1USB-B input
2Bluetooth antenna
3Toslink optical input
4Coaxial input
5IEC power supply
6RCA output
7Balanced XLR output
Product typeDAC
Dac chipES9068A
USB interfaceXMOS XU216
AOP5x OPA1612
Inputs1x USB-B input
1x Optical Toslink input
1x Coaxial SPDIF input
Bluetooth
Outputs1x RCA stereo output
1x XLR stereo output
THD+N0.00015%
Dynamic range120dB
SNR125dB
Frequency response10Hz-50kHz
USB transmissionAsynchronous
Supported sample ratesUSB: PCM 32bit 768kHz, native DSD up to DSD512, MQA.
Optical, coaxial: PCM 24bit 192kHz, DSD DoP64, MQA.
Bluetooth chipQCC5125
Bluetooth-compatible codecsSBC, AAC, aptX, aptX LL, aptX HD, LDAC
Power consumptionOperating : 5W
Standby : < 0.5W
Dimensions125 x 80 x 176mm
Weight896g
Package1x DAC FX-Audio DS07
1x Remote control
1x Bluetooth antenna
1x USB-A to USB-B cable
1x Power supply cable
DAC / ADC ChipES9068AS
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
FX-Audio unveils its DS07 balanced DAC, a compact, high-performance device with an original appearance. FX-Audio's...
