GUSTARD DAC-R26 Discrete R2R DAC I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512 Silver MQA
Gustard unveils with its DAC-R26 an absolutely exceptional digital to analog converter. This one uses an R2R architecture using discrete components of very high quality and perfectly optimized to offer exceptional sound performances. Practical, it benefits in addition to a complete connectivity, of a Bluetooth and network connectivity, allowing to control the reading of your music at distance. The whole is integrated in a sublime modern and luxurious chassis of the most beautiful effect.
By buying this product you get 159 loyalty points
Reference : 16597
1 599,00 €tax incl.
1 332,50 € tax excl.
Shipping date: 16-05-2025.
Gustard DAC-R26
Gustard DAC-R26 DAC R2R Discret I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512
Discrete R2R
The R2R DAC used in the Gustard DAC-R26 relies on high precision resistor switching to perform the digital to analog conversion. Compared to a Delta-Sigma DAC, the R2R offers a more pure and natural sound. A more expensive and demanding design, but one that offers incomparable performance.
Synchronous clock technology
The principle of this technology is that the source clock is used only as a frequency reference. The synchronous signal provided by the ultra-low noise K2 module is then used to replace the source clock. The source clock is therefore abandoned and the DAC uses only the extremely precise femtosecond clock and the conversion is therefore not affected by the source clock. This architecture thus allows a significant reduction in jitter.
LPF
The Gustard DAC-R26's LPF low-pass circuit parameters are finely optimized. The use of discrete components rather than integrated circuits allows independent adjustment of each element to achieve the best operating conditions.
Network connectivity
The DAC-26 benefits from a network connectivity thanks to its RJ45 port. It supports UPnP, AirPlay and Roon Bridge protocols. It will allow you to enjoy your music stored on your network devices.
Bluetooth 5.0
In addition to its network connectivity, the DAC-26 is also equipped with a Bluetooth 5.0 receiver chip. This one offers the possibility of controlling the reading of your music remotely, directly from your smartphone.
XMOS USB Interface
Another high quality component embedded in the DAC-26, its USB XMOS interface. This one allows him, via its USB input, to decode high resolution audio streams, until the PCM 32bit 768kHz and DSD512.
1Balanced XLR output
2I2S Input (HDMI)
3USB-B Input
4USB-C Input
5Bluetooth antenna
6Coaxial input
7AES/EBU input
810MHz Clock input
9Optical Toslink input
10Power supply voltage selection #1
11Power supply voltage selector #2
12POwer connector
13Fuse
14ON/OFF switch
15Single-ended RCA output
16RJ45 input
Gustard DAC-R26 review on Head-Fi (by Ichos)
" The Gustard R26 is one of the most musical sounding DACs of the category with great sense of realism and timbre naturalness... "
Test du Gustard DAC-R26 sur Head-Fi
Product typeDiscrete R2R DAC
Inputs1x USB-C
1x USB-B
1x RJ45
1x I2S (HDMI)
1x AES/EBU
1x Coaxial
1x Optical Toslink
Bluetooth 5.0
1x Balanced stereo XLR
Supported sampling ratesUSB / I2S / LAN : PCM up to 32bit 768kHz, Native DSD up to DSD512, DSD DoP up to DSD256
AES / Optical / Coaxial : PCM up to 24bit 192kHz, DSD DoP up to DSD64
MQA
USB CompatibilitéWindows 7/8/10/11
Mac OSX
Linux
Network protocolRoon
AirPlay
UPnP
Supported Bluetooth codecsAAC, SBC, aptX, aptX LL, aptX HD, LDAC
Frequency response20Hz-20kHz ±0.2dB
Dynamic range> 115dB
SNR> 122dB
Crosstalk-134dB @ 1kHz
THD+N≤ 0.003% @ 1kHz
IMD0.008% à 0dBFS
Output levelsRCA : 2.5Vrms (fixed volume)
XLR : 5Vrms (fixed volume)
Outpu timpedanceRCA : 100Ω
XLR : 100Ω
Supply voltage115-230VAC 50/60Hz
Consumption< 30W
Dimensions330 x 260 x 65mm
ColorSilver
InputI2S via HDMI
InputRJ45
InputAES/EBU
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate768kHz
ColorSilver
NetworkingYes
Remote ControlYes
10 reviews
SUPERBE ECOUTE !
Informé d'une nécessité de rodage avant un résultat optimum, j'ai été toutefois surpris d'obtenir immédiatement un excellent rendu, déjà supérieur à mon précédent Dac pourtant aussi R2R de qualité.
- La fabrication du Gustard R26 et la structure même des circuits internes et des composants retenus (ex: horloges), sont visiblement de la plus haute qualité.
J'ai attendu une dizaine de jours avec le Dac sous tension secteur permanente (et modulation en silence les nuits) afin de pouvoir donner un avis un minimum cohérent et crédible !
- Le son de la section Dac du Gustard R26 est tout simplement remarquable; à la fois précis, dynamique, très articulé et avec en prime un fruité de l'aigu comparable à celui d'excellents systèmes de lecture vinyle ce qui est extrêmement râre.
L'image sonore assez "panoramique" offre une belle profondeur 3D avec une agréable impression de présence réaliste des interprètes musiciens ou chanteurs.
L'écoute est d'emblée très supérieure musicalement au rendu de mes 9 ou 10 précédents Dacs.
- Son lecteur réseau intégré plus classique, bien que très correct n'a certes pas le caractère exceptionnel de la section Dac mais on doit considérer que proposer un Dac d'une telle qualité + un lecteur réseau très correct + une télécommande, + Bluetooth etc. pour un prix de 1599 € s'affiche comme un excellent rapport qualité/prix.
En conclusion: c'est probablement l'un des 3 ou 4 meilleurs Dacs actuellement disponibles sur le marché, dans une tranche allant jusqu'à env 3500 € !
Rien de moins ! !
This review has been posted for GUSTARD DAC-R26 Discrete R2R DAC I2S Bluetooth LAN AirPlay Roon DLNA 32bit 768kHz DSD512 Silver MQA
Juste la musique, un point c'est tout...
Tout a déjà été dit sur ce magnifique appareil.
J'écoute toute sorte de musiques, beaucoup de classique, d'indi, de jazz, de rock...Ce R26 ne vous décevra jamais.
Avec lui c'est juste l'essence de la musique, c'est analytique, mais pas trop, c'est dynamique, ça monte haut, respect des timbres, ça descend bas, aucune agressivité, l'image stéréo est immense en largeur et profondeur...que dire, on a juste la musique en face de soi...
J'avais lu sur les réseaux quelques problèmes avec le streamer, mais non, tout fonctionne parfaitement chez moi, Tidal connect, Bubbleupnp, LMS.
Encore au dessus d'un SMSL Su-9 qui est pourtant un DAC remarquable. Bien mis en oeuvre on a la une base de choix pour bâtir un système de haute qualité..
Pas donné bien sur, mais rapport qualité prix incroyable, et service Audiophonics impeccable.
Complément d'avis
Pour compléter mon précédent avis.
Au moins 150h de rodage sont nécessaires pour vraiment apprécier ce DAC à sa juste valeur. Le grave est plus équilibré, la scène sonore semble plus précise encore, le coté "naturel" s'accentue encore.
Vraiment très satisfait de mon achat. Un appareil qui se place largement au-dessus de la mêlée des DAC à 500 ou 1000€.
Il semblerait que Gustard ait annoncé les petits correctifs UPnP attendus sur ce R26 (et A26 aussi qui partage le même streamer).
Extra
Ce DAC qui embarque à la fois un streamer (utilisé dans mon cas avec Roon et/ou HQPlayer) est absolument fabuleux en terme de précision transparence et détails. La scène sonore est vaste. Il se dégage un certain naturel dans la restitution. Je pense que du fait de toutes ces qualités, il faut prendre soin à ce qu'on met pour accompagner cet appareil.
Le grave est massif ou autoritaire selon l'appréciation ou son système, mais très bien controlé toutefois.
Le fait de pouvoir se passer d'un streamer est vraiment très appréciable. Je pense qu'il doit falloir investir beaucoup pour aller plus loin que le streamer intégré.
Des petits moins qui sont à signaler et peuvent concerner certains:
- En mode LAN (streamer), l'UPnP présente semble t'il avec la dernière version du firmware (v1.4) des petits problèmes. Ce sera surement corrigé mais pas d'info claire de Gustard encore à ce jour.
- La documentation très très légère.
Znakomity DAC!
Tak jak pisał kolega poniżej, uzależniające granie, aż chce się słuchać. Myślę, że mój sprzęt nie wykorzystuje do końca możliwości tego DAC. Mam UR Unico Nuovo + Monitor Audio Silver 500 6G.
Gustard unveils with its DAC-R26 an absolutely exceptional digital to analog converter. This one uses an R2R architecture using discrete components...
