HIFIMAN SERENADE R2R DAC
With its Serenade, HiFiMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and network player, thanks to an RJ45 LAN port. The device was developed by HiFiMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification circuitry.
By buying this product you get 113 loyalty points
Reference : 18853
1 139,00 €tax incl.
949,17 € tax excl.
Shipping date: 06-05-2026.
The new HIFIMAN SERENADE WIFI version is now available.
HIFIMAN SERENADE DAC R2R Preamplifier Class A Headphone Amplifier LAN RJ45 32bit DSD512
DAC HIFIMAN SERENADE picture
With its Serenade, HiFiMAN unveils a versatile R2R DAC that also acts as preamplifier, headphone amplifier and network player, thanks to an RJ45 LAN port. The device was developed by HiFiMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification circuitry. The HiFiMAN Serenade's wide range of connectors and functions make it a DAC that will fit into almost any Hi-Fi installation.
HIFIMAN SERENADE DAC circuit diagram
HIFIMAN Serenade: R2R Hymalaya Pro DAC
With support from a new FGPA algorithm, Hymalaya R2R DAC technology achieves a THD of 0.0012% (-6db). Coupled with the XMOS XU316 USB interface, the Serenade DAC is able to support high-resolution PCM 32bit 384kHz and DSD256 streams via its USB input, 24bit 192kHz and DSD DoP64 streams via its coaxial SPDIF and Toslink optical inputs, as well as 32bit 768kHz and DSD512 streams via network.
Photo of DAC Hymalaya architecture
Photo of the HIFIMAN SERENADE headphone amplifier circuit
HIFIMAN Serenade: Class A headphone amplifier circuitry
The HiFiMAN Serenade's headphone amplifier circuit is based on a Class A circuit architecture for a powerful, round and warm sound. It features 3 headphone outputs on the front panel, a balanced XLR 4-pin headphone output, a balanced 4.4mm jack headphone output and a 6.35mm jack headphone output.
HIFIMAN Serenade : RJ45 LAN port
The Serenade's RJ45 port enables it to connect to a network, so you can enjoy a NAS gateway on your local network, or stream music directly to your favorite streaming applications via your phone or tablet.
HIFIMAN SERENADE network functionality
Photo of HIFIMAN SERENADE toroidal transformer
HIFIMAN Serenade: a 50W toroidal transformer
For its power supply, the HiFiMAN Serenade benefits from a 50W toroidal transformer and a high-speed, low-noise voltage regulator circuit that enables it to operate with a clean current.
Overview of HIFIMAN Serenade connectors
HIFIMAN SERENADE connectors
1XLR 4-pin balanced headphone output
26.35mm jack headphone output
3Balanced 4.4mm jack headphone output
4Input selector
5Settings
6Output selector
7Volume control
8Matrix display
9Balanced XLR stereo analog output
10RCA stereo analog output
11RCA stereo analog input
12SPDIF Coaxial input
13Optical Toslink input
14USB-B input
15RJ45 LAN port
16Power input
HiFiMAN Serenade review by ON-MAG
"Non content d’être un appareil très complet, faisant à la fois office de DAC, ampli casque, streamer et préampli stéréo, l'Hifiman Serenade brille également par sa qualité de fabrication et surtout d’un point de vue sonore. Maîtrisé de bout en bout, il parvient à combiner d’excellentes qualités techniques à une grande puissance de sortie. Une belle démonstration de la marque."
Product typeDAC R2R
Preamplifier
Headphone amplifier
DAC technologyHymalaya Pro
Inputs1x USB-B input
1x Coaxial SPDIF input
1x Toslink optical input
1x Analog RCA stereo input
Outputs1x XLR stereo balanced output
1x RCA analog output
1x XLR 4-pin balanced headphone output
1x 6.35mm jack headphone output
1x 4.4mm jack balanced headphone output
Other connectorsRJ45 port
Update port
Supported sampling ratesUSB: PCM up to  32bit 384kHz and DSD up to DSD256
Coaxial / Optical: PCM up to 24bit 192kHz and DSD DoP64
Network: PCM up to 32bit 768kHz and DSD up to  DSD512
frequency response20Hz-20kHz (+/-0.1dB @1kHz)
THD+N0.0015% (-3dBFS @ 1kHz)
SNR- 110dB (0dBFS @ 1kHz)
Channel separation- 120dB (0dBFS @ 1kHz)
DAC output levelXLR : 4.5V RCA : 2.5V
Headphone output power (@THD+N<0.07% @1kHz)Balanced XLR and 4.4mm jack outputs: 4000mW @ 32Ω / 760mW @ 300Ω
6.35mm jack headphone output: 2800mW @32Ω / 510mW @ 300Ω
Dimensions300 x 255 x 50mm
Net weight3.9Kg
Package1x HifiMan Serenade
1x Main power cable
InputRJ45
OutputJack 4.4mm
OutputJack 6.35mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rateDSD512
Max sampling rate768kHz
NetworkingYes
Streaming services & Network protocolsNC
HIFIMAN SERENADE DAC R2R Preamplifier Headphone Amplifier Class A LAN RJ45 32bit DSD512
With its Serenade, HiFiMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and network player, thanks to an RJ45...
