By buying this product you get 86 loyalty points
With its Serenade WiFi, HIFIMAN unveils a versatile R2R DAC that also acts as a preamplifier, headphone amplifier and streamer, thanks to an RJ45 LAN port and WiFi functionality. The device was developed by HIFIMAN in collaboration with GoldenWave. It features R2R Hymalaya Pro conversion technology, as well as an XMOS XU316 USB interface and Class A headphone amplification circuitry. The HIFIMAN Serenade's wide range of connectors and functions make it a DAC that will fit into almost any Hi-Fi installation.
A new version of the HIFIMAN Serenade, this version integrates WiFi functionality for enhanced wireless connectivity. The HIFIMAN offers full network player functionality for optimum versatility. A true gateway, it supports numerous applications for easy access to all your music libraries.
With support from a new FGPA algorithm, Hymalaya R2R DAC technology achieves a THD of 0.0012% (-6db). Coupled with the XMOS XU316 USB interface, the Serenade DAC is able to support high-resolution PCM 32bit 384kHz and DSD256 streams via its USB input, 24bit 192kHz and DSD DoP64 streams via its coaxial SPDIF and Toslink optical inputs, as well as 32bit 768kHz and DSD512 streams via network.
The HIFIMAN Serenade's headphone amplifier circuit is based on a Class A circuit architecture for a powerful, round and warm sound. It features 3 headphone outputs on the front panel, a balanced XLR 4-pin headphone output, a balanced 4.4mm jack headphone output and a 6.35mm jack headphone output.
The Serenade's RJ45 port enables it to connect to a network, so you can enjoy a NAS gateway on your local network, or stream music directly to your favorite streaming applications via your phone or tablet.
For its power supply, the HIFIMAN Serenade benefits from a 50W toroidal transformer and a high-speed, low-noise voltage regulator circuit that enables it to operate with a clean current.
| 1 | XLR 4-pin balanced headphone output |
| 2 | Single-ended 6.35mm jack headphone output |
| 3 | Balanced 4.4mm jack headphone output |
| 4 | Input selector |
| 5 | Settings |
| 6 | Output selector |
| 7 | Volume control |
| 8 | Matrix display |
| 9 | Balanced XLR stereo analog output |
| 10 | Single-ended RCA stereo analog output |
| 11 | Single-ended RCA stereo analog input |
| 12 | Coaxial input |
| 13 | Optical Toslink input |
| 14 | USB-B input |
| 15 | WiFi Antenna |
| 16 | RJ45 LAN port |
| 17 | Update port |
| 18 | Power input |
"The Hifiman Serenade is not only a very complete device, acting as a DAC, headphones amp, streamer and stereo preamp in one, it also shines in terms of build quality and, above all, sound quality. Mastered from start to finish, it manages to combine excellent technical qualities with high output power. A fine demonstration of the brand."
| Specifications | |
| Product type | DAC R2R Preamplifier Headphone amplifier Streamer |
| DAC technology | Hymalaya Pro |
| Inputs | 1x USB-B 1x Coaxial 1x Toslink optical 1x RCA stereo WiFi |
| Outputs | 1x Balanced XLR stereo 1x Single-ended RCA stereo 1x Balanced XLR 4-pin headphone output 1x Single-ended 6.35mm jack headphone output 1x Balanced 4.4mm jack headphone output |
| Other connectors | RJ45 port Update port |
| Compatible protocols | UPnP/DLNA, AirPlay, Roon Ready |
| Supported sampling rates | USB: PCM up to 32bit 384kHz, DSD up to DSD256 Coaxial / Optical: PCM up to 24bit 192kHz, DSD DoP64 Network: PCM up to 32bit 768kHz, DSD up to DSD512 |
| Frequency response | 20Hz-20kHz (+/-0.1dB @1kHz) |
| THD+N | 0.0015% (-3dBFS @ 1kHz) |
| SNR | - 110dB (0dBFS @ 1kHz) |
| Channel separation | - 120dB (0dBFS @ 1kHz) |
| DAC output level | XLR : 4.5V RCA : 2.5V |
| Headphone output power (@ THD+N < 0.07% @ 1kHz) | Balanced XLR and 4.4mm jack outputs: 4000mW @ 32Ω / 760mW @ 300Ω Single-ended 6.35mm jack headphone output: 2800mW @ 32Ω / 510mW @ 300Ω |
| General | |
| Dimensions | 300 x 255 x 50mm |
| Net weight | 3.9Kg |
| Color | Black |
| Package | 1x HIFIMAN Serenade WiFi 1x Power cable |
| Input | RJ45 |
| Input | RCA |
| Input | Optical |
| Input | WiFi |
| Input | USB |
| Input | SPDIF |
| Output | RCA |
| Output | Jack 6.35mm |
| Output | XLR |
| Output | Jack 4.4mm |
| DAC / ADC Chip | R2R LADDER DAC |
| Color | Black |
| Networking | Yes |
| Remote Control | No |
| Streaming services & Network protocols | Tidal Connect |
| Streaming services & Network protocols | UpnP |
| Streaming services & Network protocols | DLNA |
| Streaming services & Network protocols | Spotify Connect |
| Streaming services & Network protocols | Roon / Roon Bridge / Roon Ready |
| Streaming services & Network protocols | Qobuz |
| Streaming services & Network protocols | AirPlay |
