IFI AUDIO ZEN AIR DAC Burr Brown XMOS 32bit 384kHz DSD256 MQA
iFi Audio offers with the Zen Air DAC an efficient and affordable digital to analog converter, even including an amplified headphone output. Its conversion stage is based on a Burr Brown chip, associated with a 16-core XMOS USB interface, allowing the device to decode high-resolution audio streams, up to PCM and DXD 32bit 384kHz as well as native DSD up to DSD256. The Zen Air DAC is even compatible with MQA (Master Quality Authenticated) files, allowing you to enjoy high quality files at a reduced weight, especially via the Tidal streaming platform.
Reference : 16630
99,00 €tax incl.
82,50 € tax excl.
Last items in stock !
Shipping date: 10-06-2025.
iFi Audio Zen Air DAC
iFi Audio Zen Air DAC DAC Burr Brown XMOS 32bit 384kHz DSD256 MQA
PowerMatch & XBass+
Zen Air DAC also incorporates two technologies that allow it to adapt to your audio system and your listening experience. The first one, PowerMatch, allows Zen Air DAC to adjust the gain level of its headphone output according to the impedance of your headphones. The second one, XBass+, allows you to adjust the bass level according to your listening equipment and your personal taste.
Analog volume control
iFi Audio also includes an analog volume control in its Zen Air DAC. This allows a non-destructive adjustment of the sound level, unlike a digital control.
Product typeDAC
Input1x USB-B
Outputs1x Stereo RCA
1x Jack 6.35m headphone output
DAC ChipBurr Brown
USB InterfaceXMOS
Native DSD up to DSD256
DXD up to 32bit 384kHz
MQA
Output levelLine output : 1V / 3.3V max.
Headphone output : 1V / 3.3V max. (variable)
Output impedanceLine output : ≤ 50Ω
Headphone output : < 1Ω
SNRLine output : < -113dB(A) @ 0dBFS
Headphone output : > 113dBA (3.3V)
THD+NLine output : < 0.04% @ 0dBFS
Headphone output : < 0.04% @ 100mW, 16Ω
Dynamic range (line output)> 113dB(A) @ -60dBFS
Headphone output power> 230mW @ 32Ω
> 36mW @ 300Ω
Supply voltage5VDC 2.5A (câble USB-A vers USB-B fourni)
ConsumptionNo signal : ~ 0.5W
Max signal : ~ 2.5W
Dimensions158 x 117 x 35mm
Weight315g
OutputJack 6.35mm
DAC / ADC ChipBurr Brown
Max sampling rate384kHz
Max sampling rateMQA
Max sampling rateDSD256
ColorGray
iFi Audio offers with the Zen Air DAC an efficient and affordable digital to analog converter, even including an amplified headphone output. Its...
