LOXJIE D30 V2 DAC ES9068AS Headphone Amplifier XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512
Loxjie offers its D30, a particularly powerful and affordable DAC and headphone amplifier combo, in a V2 version now equipped with an ESS ES9068AS digital/analog conversion chip. This, in association with an optimized general architecture, allows to reach a rich and precise sound restitution. It also offers full connectivity for easy integration into the vast majority of audio systems.
Reference : 15638
299,00 €tax incl.
249,17 € tax excl.
Shipping date: 15-05-2025.
Loxjie D30 V2
Loxjie D30 V2 DAC ES9068AS Amplificateur Casque XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512
ESS ES9068AS DAC
At the heart of the D30 V2's digital-to-analog conversion stage, a 32bit ESS ES9068AS DAC ensures excellent audio performance. It has a very low THD+N of only 0.0001% (-120dB) and supports high sampling rates up to 32bit 768kHz and DSD512. It also allows the decoding of MQA files.
MQA decoding and rendering
MQA (for Master Quality Authenticated) is an award-winning British technology that restores the sound quality of original recordings. MQA files are also light enough to stream or download. The D30 V2 supports MQA technology, allowing you to play and stream MQA files for superior sound quality.
USB XMOS Interface
The Loxjie D30 V2 has an excellent second generation XMOS interface for its USB input. It allows a fast and efficient decoding of data, while supporting high definition audio streams.
Bluetooth
Practical, the Loxjie D30 V2 allows you to transmit your audio files remotely, in Bluetooth, directly from your smartphone. The Bluetooth 5.0 standard associated with the aptX HD protocol allows a stable and high quality transmission, close to CD quality.
Preamplifier mode
The D30 V2 has a preamplifier output on stereo RCA. This preamplifier mode has two different settings: The fixed mode blocks the output level at 2Vrms and the variable mode allows you to take advantage of the volume control of the device.
Independent power supply
A specially designed low-noise regulated power supply provides a clean and stable electrical signal to all audio circuits, promoting beautiful transparency and clarity of sound. It also keeps power consumption low, below 5W in operation.
A complete connectivity
The D30 V2 offers a complete connectivity, allowing it to be integrated into many audio systems. We find in input USB-B, Coaxial, Optical in addition to the Bluteooth 5.0 connectivity. For its outputs, the Loxjie DAC has a stereo RCA and a headphone output in front of the 6.35mm jack format.
Robust and elegant
The V30 V2's components are housed in an elegant and robust aluminum case, providing excellent rigidity that also eliminates chassis vibration, while limiting the impact of electromagnetic interference on the circuits.
1Screen
2Jack 6.35mm headphone output
3Multifunction button
4RCA Output
5Bluetooth antenna
6Optical input
7Coaxial input
8USB Input
9Power supply
10Power button
Product typeDAC
Headphone amplifier
InputsBluetooth 5.0
1x SPDIF Coaxial
1x Optical Toslink
1x USB-B
Outputs1x Stereo RCA
1x Jack 6.35mm headphone output
Headphone output power2x 110mW @ 32Ω
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 912kHz, DSD DoP up to DSD64
Bluetooth codecsSBC, AAC, aptX, aptX HD
THD+N0.0001% (-120dB)
Output level2Vrms
Dynamic range123dB
SNR123dB
Output impedanceRCA : 100Ω
Headphone output : 1.1Ω
USB TransmissionAsynchronous
USB CompatibilityWindows 7 / 8 / 8.1 / 10
Mac OS X
Linux
Supply voltage100-240VAC (included power cable)
ConsumptionOperating: 5W
Standby : < 0.5W
Dimensions170 x 151 x 38mm
Weight535g
Package1x Loxjie D30 V2
1x Remote control
1x Antenna
1x USB Cable
1x Power cable
OutputJack 6.35mm
DAC / ADC ChipES9068AS
Max sampling rateDSD512
Max sampling rate768kHz
ClassN/A
Remote ControlYes
2 reviews
Ravi de cette acquisition
Je n'ai pas encore testé entière ce Dac. Je suis impressionné par la qualité de fabrication et le son. J'ai toutefois un petit souci : connecté en usb sur mon Mac, je ne peux pas régler le son au clavier, je suis obligé d'utiliser la télécommande ou le bouton de volume. Si quelqu'un sait pourquoi ? Merci
This review has been posted for LOXJIE D30 V2 DAC ES9068AS Headphone Amplifier XMOS Bluetooth 5.0 MQA 32bit 768kHz DSD512
excellent DAC
Ce DAC est venu en remplacement d'un ADVANCE ACOUSTIC MDX 600. Le LOXJIE est indéniablement un cran au-dessus mais en même temps les deux DAC ne sont clairement pas de la même génération. Ce LOXJIE, relié à mon ampli BC ACOUSTIQUE, apporte beaucoup de détails, de la finesse, de la matière, de la dynamique et propose au final une vraie musicalité assurant de longues séances d'écoute sans fatigue auditive sur tout type de musique (pour ma part essentiellement du jazz, de la musique classique et contemporaine). Je trouve sa restitution un chouïa plus ciselée que celle du SMSL SU8 de mon installation principale (branché lui aussi en RCA et non en XLR car mon ampli n'a pas ce style de prises), matériel qui néanmoins sonne lui aussi très bien (les deux styles de restitution étant vraiment très proches).
L'écoute du LOXJIE au casque sur mon bon vieux AKG est très bonne, de sorte que je rejoins tout à fait les conclusions d'Audiosciencereview, à savoir que ce matériel constitue une très bonne affaire pour qui souhaite avoir un combo qualitatif DAC + ampli casque.
J'ajoute que l'alim intégrée semble au-dessus de la moyenne de celles figurant dans ce style d'appareils et que c'est un point qui pour ma part me rassure (je suis d'une génération habituée aux bons gros transfos...).
La vraie note serait néanmoins 4,5 et non 5 car je considère que presque tous ces DAC encore abordables manquent d'entrées : j'aurais apprécié une ou deux autres optiques et/ou coax (pour rester dans des styles de prises relativement peu onéreuses à implémenter). Je pense représenter un mélomane assez typique (au sens "banal"), avec un lecteur CD, un ordi et un disque dur multimedia pour les CD rippés. Or, quand il n'y a que 3 entrées de valeur (je n'inclue pas BT), on fait comment pour relier la télé en numérique ?? Sur mon Advance, il y avait pléthore d'entrées et, sur ce point...c'était mieux.
Enfin, côté fiabilité : rien à déplorer après plus d'un an d'utilisation, le DAC sonne comme au premier jour.
Au plaisir.
Loxjie offers its D30, a particularly powerful and affordable DAC and headphone amplifier combo, in a V2 version now equipped with an ESS ES9068AS...
