The SMSL C200 Pro is a versatile, high-performance DAC / headphone amplifier based on market-renowned audiophile components. It incorporates an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than four OPA1612A OPAs. This enables it to support high-definition sampling rates up to PCM 32bit 768kHz and DSD512, while delivering headphone output power of up to 2x1.5W into 32 ohms. Added to this is Bluetooth 5.1 functionality, enabling it to handle high-definition codecs such as aptX, aptX-HD and LDAC. On the connectivity side, there are a number of digital inputs, USB-C, Toslink optical and coaxial, while on the output side, there's a single-ended RCA output and a balanced TRS jack output. There are also two headphone outputs on the front panel: single-ended 6.35mm jack and balanced 4.4mm jack. As for the appearance and aesthetics of the SMSL C200 Pro, the brand has opted for simplicity and elegance, while integrating a small display.
The XMOS XU316 USB interface enables the SMSL C200 PRO to support sampling rates up to PCM 32bit 768kHz and DSD512.
The ES9039Q2M DAC chip not only handles high-resolution sampling rates, but also offers exceptional performance, with a dynamic range of up to 130dB, low THD of -126dB and THD+N of -120dB.
Thanks to a Qualcomm Bluetooth receiver chip, the SMSL C200 Pro supports high-definition codecs for the most reliable and stable wireless connection: SBC, AAC, aptX, aptX-HD and LDAC (24bit 96kHz).
No fewer than four OPA OPA1612A amplifiers are used to amplify the single-ended 6.35mm jack and balanced 4.4mm jack headphone outputs, giving the SMSL C200 Pro the ability to drive a wide range of headphones and earphones, including high-impedance models.
Headphones amplification power | 2x 3W @ 16 ohm |
2x 1.5W @ 32 ohm | |
2x 350mW @ 150 ohm | |
2x 170mW @ 300 ohm | |
2x 85mW @ 600 ohm | |
Headphone amplifier gain | +9.5dB |
1 | Single-ended 6.35mm jack headphone output |
2 | Balanced 4.4mm jack headphone output |
3 | Multifunction button |
4 | IR receiver |
5 | Display |
6 | Power supply |
7 | Bluetooth antenna |
8 | Optical Toslink input |
9 | USB-C input |
10 | Coaxial input |
11 | Single-ended RCA output |
12 | Balanced 6.35mm TRS jack output |
Product type | DAC / Headphone amplifier |
DAC chip | ES9039Q2M |
USB interface | XMOS XU316 |
OPA | 4x OPA1612A |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth |
Outputs | 1x Single-ended stereo RCA 1x Balanced stereo 6.35mm TRS jack 1x Single-ended 6.35mm headphone output 1x Balanced 4.4mm headphone output |
Supported sampling rates | USB: PCM up to 32bit 768kHz, DSD up to DSD512 Toslink optical and coaxial: PCM up to 24bit 192kHz, DSD DoP64 |
Bluetooth version | 5.1 |
Supported Bluetooth codecs | AAC, SBC, aptX, aptX-HD, LDAC |
Max. variable output level | Single-ended RCA : 2.5Vrms Balanced Jack TRS : 5Vrms |
Headphone output power | 2x 3W @ 16 ohm 2x 1.5W @ 32 ohm 2x 350mW @ 150 ohm 2x 170mW @ 300 ohm 2x 85mW @ 600 ohm |
Headphone output gain | +9.5dB |
THD+N | Line output: 0.00006% (-123.5dB) Headphone output: 0.00009% (-120dB) |
Dynamic range | RCA: 126dB Jack 6.35mm TRS: 129dB Headphone amp: 125dB |
SNR | RCA: 126dB Jack 6.35mm TRS: 129dB Headphone amp: 125dB |
Output impedance | Line output: 100 ohm Headphone output: near 0 ohm |
USB transmission | USB 1.1 and USB 2.0 (asynchronous) |
USB compatibility | Windows 7/8/8.1/10/11 (with driver) MAC OS, Linux, IOS, Android (without driver) |
Power supply | 100-240V AC |
Color | Black |
Dimensions | 139 x 147.5 x 32mm |
Weight | 510g |
Package | 1x SMSL C200 Pro 1x IR remote control 1x Bluetooth antenna 1x USB-A to USB-C cable 1x Power supply cable |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | SPDIF |
Output | Jack 6.35mm |
Output | RCA |
Output | Jack 4.4mm |
DAC / ADC Chip | ES9039Q2M |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Class | Class A / AB |
Networking | No |
Remote Control | Yes |
