SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512
The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion chips and a second generation USB XMOS interface. It supports high sampling rates, up to PCM 32bit 768kHz and DSD512. The whole set benefits from a smart and careful design, using only quality components.
Reference : 16593
179,00 €tax incl.
149,17 € tax excl.
SMSL D-6
Differences between the SMSL SU-6 and D-6
D-6
SU-6
DAC Chip
2x AK4493S
1x ES9038Q2M
Jitter suppression technology
CK-03 Clock module
DPLL integrated in the ES9038Q2M DAC
Balanced output
2x Jack 6.35mm TRS
Non
THD+N
-118.5dB
-119dB
Dynamic range
123dB
125dB
Power supply
Integrated, low noise
Dimensions
148 x 112.8 x 27.5mm
140 x 100 x 27mm
Weight
450g
350g
AK4493S Dual DAC
The heart of the SMSL D-6, its digital to analog conversion stage, embeds two AKM AK4493S DAC chips. This one offers excellent performances with an ultra-low distortion and a wide dynamic range, going up to 123dB.
XMOS USB Interface & High-End Components
The dual AKM DAC is supported by a second generation XMOS high-end USB receiver chip. It enables the D-6 to decode high-resolution audio streams up to 32bit 768kHe PCM and native DSD512. In addition, the combination of the AK4493S DACs and this USB interface ensures accurate and detailed sound reproduction.
Of course, the D-6 does not limit itself to this combination, but also incorporates a CK-03 clock module for very low jitter and a high-performance filtered power supply stage.
Bluetooth 5.1
SMSL has equipped the D-6 with the latest Qualcomm QCC5125 chip, which offers high-resolution Bluetooth 5.1 reception capability, including support for aptX HD and LDAC codecs.
Full connectivity
The D-6 is equipped with a complete connectivity, allowing an integration within the majority of the audio systems. In addition to Bluetooth connectivity, the D-6 offers USB-C, coaxial and optical Toslink. For its outputs, the D-6 offers single-ended stereo RCA as well as a balanced output on Jack 6.35mm TRS.
1IR Receiver
2Display
3Multi-function button
4Bluetooth antenna
5Power connector
6USB-C input
7Optical input
8Coaxial input
9RCA output
10Balanced TRS Jack 6.35mm output
Product typeDAC
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth 5.0
Outputs1x Stereo RCA
1x Balanced TRS Jack 6.35mm
Output levelsTRS : 4Vrms
RCA : 2Vrms
THD+N0.0001% (119.5dB) @ A-Weighted
Dynamic rangeTRS : 123dB
RCA : 120dB
SNRTRS : 122dB
RCA : 119dB
USB TransmissionAsynchronous
USB CompatibilitéWindows 7/8/8.1/10
Mac OS X10.6 or later
Linux
Supported sampling ratesUSB : PCM up to 32bit 768kHz, DSD up to DSD512
Optical / Coaxial : PCM up to 24bit 192kHz
Supply voltage100-240VAC
Consumption2W
Standby : < 0.1W
Dimensions148 x 112.8 x 27.5mm
Weight450g
SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512 SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512
OutputJack 6.35mm
DAC / ADC ChipAK4493S
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
2 reviews
Le D6
Excellent petit dac (chaleur/profondeur/même les graves sont mordants) ! Quelle belle surprise en ligne avec ampli de puissance (je vais essayer avec un preamp bientôt). Livraison rapide comme d'habitude. Merci.
This review has been posted for SMSL D-6 DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512
A great improvment
After installing the SMSL D-6 sound from PC via USB and from Bluray via Coaxial was immediately improved. I was impressed how much the atmosphere and ambience of my blurays gained. Shit, now I have to watch all my blurays a-new.
The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion...
