Excellent petit dac (chaleur/profondeur/même les graves sont mordants) ! Quelle belle surprise en ligne avec ampli de puissance (je vais essayer avec un preamp bientôt). Livraison rapide comme d'habitude. Merci.
DAC 2x AK4493S XMOS Bluetooth 5.1 aptX HD LDAC 32bit 768kHz DSD512
The D-6 joins SMSL's wide range of DACs, offering excellent performance for a contained price. It is equipped with two AKM AK4493S conversion chips and a second generation USB XMOS interface. It supports high sampling rates, up to PCM 32bit 768kHz and DSD512. The whole set benefits from a smart and careful design, using only quality components.
D-6
SU-6
DAC Chip
2x AK4493S
1x ES9038Q2M
Jitter suppression technology
CK-03 Clock module
DPLL integrated in the ES9038Q2M DAC
Balanced output
2x Jack 6.35mm TRS
Non
THD+N
-118.5dB
-119dB
Dynamic range
123dB
125dB
Power supply
Integrated, low noise
Dimensions
148 x 112.8 x 27.5mm
140 x 100 x 27mm
Weight
450g
350g
The heart of the SMSL D-6, its digital to analog conversion stage, embeds two AKM AK4493S DAC chips. This one offers excellent performances with an ultra-low distortion and a wide dynamic range, going up to 123dB.
The dual AKM DAC is supported by a second generation XMOS high-end USB receiver chip. It enables the D-6 to decode high-resolution audio streams up to 32bit 768kHe PCM and native DSD512. In addition, the combination of the AK4493S DACs and this USB interface ensures accurate and detailed sound reproduction.
Of course, the D-6 does not limit itself to this combination, but also incorporates a CK-03 clock module for very low jitter and a high-performance filtered power supply stage.
SMSL has equipped the D-6 with the latest Qualcomm QCC5125 chip, which offers high-resolution Bluetooth 5.1 reception capability, including support for aptX HD and LDAC codecs.
The D-6 is equipped with a complete connectivity, allowing an integration within the majority of the audio systems. In addition to Bluetooth connectivity, the D-6 offers USB-C, coaxial and optical Toslink. For its outputs, the D-6 offers single-ended stereo RCA as well as a balanced output on Jack 6.35mm TRS.
1 | IR Receiver |
2 | Display |
3 | Multi-function button |
4 | Bluetooth antenna |
5 | Power connector |
6 | USB-C input |
7 | Optical input |
8 | Coaxial input |
9 | RCA output |
10 | Balanced TRS Jack 6.35mm output |
Product type | DAC |
Inputs | 1x USB-C 1x Optical Toslink 1x Coaxial Bluetooth 5.0 |
Outputs | 1x Stereo RCA 1x Balanced TRS Jack 6.35mm |
Output levels | TRS : 4Vrms RCA : 2Vrms |
THD+N | 0.0001% (119.5dB) @ A-Weighted |
Dynamic range | TRS : 123dB RCA : 120dB |
SNR | TRS : 122dB RCA : 119dB |
USB Transmission | Asynchronous |
USB Compatibilité | Windows 7/8/8.1/10 Mac OS X10.6 or later Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz |
Supply voltage | 100-240VAC |
Consumption | 2W Standby : < 0.1W |
Dimensions | 148 x 112.8 x 27.5mm |
Weight | 450g |
Color | Black |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Output | Jack 6.35mm |
Output | RCA |
DAC / ADC Chip | AK4493S |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Black |
Networking | No |
Remote Control | Yes |
Average votes 5.0 / 5 2 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Eric K.
Klaus S.
