SMSL D-6S DAC ES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
SMSL presents its D-6S, a compact, high-performance DAC. This small D-6S DAC features an ESS ES9039Q2M DAC chip, four dual OPA1612 AOPs, a Bluetooth 5.1 receiver chip and an XMOS XU316 USB interface. In terms of performance, this DAC is capable of decoding 32bit 768kHz PCM, DSD up to DSD512, as well as MQA and MQA-CD streams.
Reference : 18318
199,00 €tax incl.
165,83 € tax excl.
Shipping date: 06-05-2025.
SMSL D-6S
SMSL presents its D-6S, a compact, high-performance DAC. This small D-6S DAC features an ESS ES9039Q2M DAC chip, four dual OPA1612 AOPs, a Bluetooth 5.1 receiver chip and an XMOS XU316 USB interface. In terms of performance, this DAC is capable of decoding 32bit 768kHz PCM, DSD up to DSD512, as well as MQA and MQA-CD streams. Its complete connectivity means it can be easily integrated into any Hi-Fi installation, with numerous input source possibilities.
ES9039Q2M DAC chip and XMOS XU316 USB interface
The D-6S DAC features an ESS ES9039Q2M chip. This DAC chip is a high-performance 32bit stereo chip specially designed for professional audio applications. It is based on Hyperstream IV Dual DAC technology and SABRE HiFi® architecture. Coupled with a latest-generation XMOS XU316 USB interface, it enables the D-6S to decode high-resolution streams via its USB-C input : PCM 32bit 768kHz and DSD512.
Support of MQA and MQA-CD streams
SMSL has also chosen to equip its D-6S with an MQA decoder, enabling it to receive very high-resolution MQA and MQA-CD streams for the purest, cleanest sound possible via its USB-C, optical and coaxial inputs.
Bluetooth 5.1
A Bluetooth receiver chip enables the D-6S to work with a remote source such as your smartphone. Bluetooth functionality supports SBC, AAC, aptX HD and LDAC formats.
Quality components for high performance
The D-6S's clock circuit considerably reduces jitter. In addition, numerous low-noise power supply components are integrated into this DAC. These design details enable it to achieve good measurement performance, with a THD+N of just 0.00006% (-123dB). The front panel features an integrated display and gold-plated connector contacts for improved signal transmission and resistance to corrosion and oxidation.
Remote control
The SMSL RC-8C remote control is supplied with this DAC, enabling you to control the D-6S remotely.
Complete connectivity
1Screen
2IR receiver
3DSD indicator
4MQA indicator
5Standby indicator
6Control knob
7Stereo RCA output
8Balanced stereo RCA output
9SPDIF Coaxial input
10Bluetooth antenna connector
11USB-C input
12Toslink optical input
13IEC power connector
Test du SMSL D-6S par AudioScienceReview (Amir)
I pride myself in always finding something to complain about in a review but I have nothing for you here. Price is right. The look is right. And performance is top notch regardless of price. I always recommend balanced DACs and here is your chance to get one without any compromise. I am happy to recommend the SMSL D-6s DAC. "
Product typeDAC
DAC ChipES9039Q2M
USB interfaceXMOS XU316
Inputs1x USB-C
1x Optical Toslink
1x Coaxial
Bluetooth
1x Balanced stereo XLR
THD+N0.00006% (-123dB)
Output levelXLR: 5Vrms
RCA: 2.5Vrms
Output impedanceXLR: 100Ω
Dynamic rangeXLR: 129dB
RCA: 126dB
SNRXLR: 129dB
RCA: 126dB
USB transmission typeAsynchronous
USB compatibilityWindows 7 / 8 / 9 / 10 / 11 (With driver)
MAC OSX 10.6 and more
Linux
Supported sample ratesUSB: PCM 32bit 768kHz, DSD DoP256, DSD512, MQA and MQA-CD
Optical Toslink and Coaxial: PCM 24bit 192kHz, DoP64, MQA and MQA-CD
Bluetooth5.1
Supported bluetooth formatsSBC, ACC, aptX, aptX HD, LDAC
Power consumption< 10W
(Standby : < 0.5W)
Dimensions150 x 42 x 128.5mm
Net weight0.59kg
Package1x DAC SMSL D-6S
1x SMSL RC-8C remote control
1x Bluetooth antenna
1x Power cable
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
Remote ControlYes
8 reviews
Excellent rapport Q/P
En remplacement d´un preampli denon Hc (1000€ il y a 10 ans)
Le d6s est plus dynamique, une meilleure séparation des sons particulièrement sur les voix féminine et à un grave plus nuancé
De plus la partie Bluetooth en LDAC est bluffante
Pour le tarif, foncez!
This review has been posted for SMSL D-6S DAC ES9039Q2M XMOS XU316 Bluetooth 5.1 32bit 768kHz DSD512 MQA
Compact, XLR out and balanced sound: all I need!
I use this DAC for conversion duties between my TV and active speakers. Happy to say that it ticks all the boxes for me. XLR out, solid build, foolproof and logical operation and most importantly: a detailed and balanced sound. It does not outperform the dac in my audio set (and it shouldn't at just 10% (!) of the price of the audio dac), but it would make me rethink the audio dac should I have to purchase that now. Recommended!
Un rapport performance très bon dans cette gamme
De très bonnes performances musicales et très complet.
Les DACs ont fait des progrès énormes il y a 10 ans il aurait fallu sortir 5 à 6 fois d'argent sans compter l'inflation
Pas mal, satisfaisant.
C'est mon premier DAC. Combiné à un ampli Studio old school BGW 750G et des baffle Vulkan Mk3 j'en suis ravis. Ce n’a pas été le grand changement vus que j'utilisais ma sortie PC qui inclus déjà une sortie piloté par un OPA 2134, une Gigabyte Gaming, mais les graves sont mieux maîtrisé, plus sec et l'ensemble est plus aéré, plus propre, les instruments sont mieux détachés.
Mes VU m'indiques aussi une dynamique accrue. Le branchement est fait avec des câbles Sommer XLR, qualité Studio.
A l'écoute de Poem of Chinese Drum je fus complémentent convaincu: les tambours sont comme des coups de foudre avec la vibrations des peaux... sublime. Et après My Bass, quelle profondeur... ou Bass Drops...
Un bon choix si on veut un DAC simple, performant et pas cher.
Voyons la durée de vie...
amazing dac
It sounds amazing;i have tried usb and coaxial inputs.The biggest surprise was the way the games in windows sounded.As always with smsl replace the usb cable.Alsi there were no batteries for the remote control and the power cord is too short; about 1m.This is the best dac i have ever owned.
SMSL presents its D-6S, a compact, high-performance DAC. This small D-6S DAC features an ESS ES9039Q2M DAC chip, four dual OPA1612 AOPs, a...
