SMSL DL200 DAC ES9039Q2M Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD
The SMSL DL200 is a high-performance DAC featuring high-quality components such as an ES9039Q2M chip, a USB XMOS XU316 interface and a Qualcomm Bluetooth receiver chip. The DL200 can decode high sampling rates, up to PCM 32bit 768kHz, DSD512 and DoP64. It can also decode MQA files up to MQA-CD.
4.5 / 5
By buying this product you get 20 loyalty points
Reference : 18053
209,00 €tax incl.
174,17 € tax excl.
Shipping date: 05-08-2025.
SMSL DL200
SMSL DL200 DAC Amplificateur Casque ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD
The SMSL DL200 is a high-performance DAC featuring high-quality components such as an ES9039Q2M chip, a USB XMOS XU316 interface and a Qualcomm Bluetooth receiver chip. The DL200 can decode high sampling rates, up to PCM 32bit 768kHz, DSD512 and DoP64. It can also decode MQA files up to MQA-CD. But that's not all: the DL200 also acts as a headphone amplifier with its two heaphones outputs (6.35mm and 4.4mm balanced). Overall, it features a wide range of connectors, including a USB-C input, a Toslink optical input, a coaxial input, as well as an RCA output and a balanced output on a 6.35mm TRS jack.
A high-performance DAC
SMSL with its DL200 offers a device capable of decoding up to PCM 32bit 768kHz, DSD512 and DoP64 thanks to its ES9039Q2M 32bit stereo DAC chip using Hyperstream® IV Dual Dac™ technology and advanced SABRE HiFi® architecture. It also benefits from an MQA decoder enabling it to receive MQA-CD streams.
XMOS XU316 USB input
The USB XMOS XU316 interface on a USB-C port can operate in 2.0 or 1.1 mode. The 2.0 interface requires a driver and supports 32bit 768kHz and DSD512. The 1.1 interface supports up to 24bits 96kHz without a driver, enabling you to connect a wide range of sources such as consoles (PS5, XBOX, Switch, etc.), your TV or Android devices.
Bluetooth 5.1 functionality
A Qualcomm Bluetooth receiver chip enables transmission of LDAC 24bit/96kHz, aptX HD, adaptive aptX, SBC and ACC formats.
Headphone amplifier
On the front of the DL200 are two headphone outputs. One 6.35mm jack and one 4.4mm balanced jack. Output power enables the SMSL DL200 to drive a wide range of headphones and earphones from 16Ω to 300Ω.
Infrared remote control
An infrared remote control lets you operate the DL200 remotely, for a more pleasant listening experience. You can adjust all the settings available in the DL200 menu.
PCM filters with DPLL
The DL200 incorporates 7 PCM filters and DPLL (Digital Phase Locked Loop) to significantly improve the input signal clock when required.
SMSL DL200 connectivity
16.35mm jack headphone output
2Balanced 4.4mm jack headphone output
3Bluetooth antenna
4Display
5Multifunction knob
6power supply IEC
7USB-C input
8Toslink optical input
9Bluetooth antenna connector
10Coaxial SPDIF input
11Stereo RCA output
12Balanced 6.35mm TRS jack output
Product typeDAC
Headphone amplifier
DAC chipES9039Q2M
OPA4x OPA1632
Inputs1x USB-C
1x Optical Toslink
1x Coaxial SPDIF
Bluetooth
Outputs1x RCA stereo
1x TRS stereo balanced
6.35mm headphone output
Headphone output 4.4mm jack
Output levelRCA: 2.5Vrms
TRS: 5Vrms
Headphone output power2x 3W @16Ω
2x 1.5W @32Ω
Headphone gainLow : 0dB
High : 11dB
THD+NLine outputs: 0.00006% (-123dB)
Headphone outputs: 0.00009% (-120dB)
Dynamic rangeTRS: 130dB
RCA: 127dB
Headphone outputs: 125dB
SNRTRS: 130dB
RCA: 127dB
Output impedanceLine outputs: 100Ω
Headphone outputs: close to 0dB
USB transmission protocol1.1 and 2.0 (Asynchronous)
USB compatibilityWindows 7/8/9/10/11 (with driver)
Android
Max OSX 10.6 and higher
Linux (without driver)
Bit depthUSB: 16-32bit
Optical / SPDIF: 16-24bit
Supported sample ratesUSB: PCM 32bit 768kHz, native DSD up to DSD512
Optical and coaxial: PCM 24bit 192kHz and DoP64
Bluetooth5.1
Supported Bluetooth codecsLDAC, aptx HD, aptX adaptative, AAC, SBC
Power consumption< 30W
Standby power consumption< 0.5W
Dimensions221.9 x 31 x 206.7
Weight1.390kg
Package1x SMSL DL200 DAC
1x Remote control
OutputJack 6.35mm
OutputJack 4.4mm
DAC / ADC ChipES9039Q2M
Max sampling rate768kHz
Max sampling rateDSD512
Max sampling rateMQA
ClassN/A
Remote ControlYes
4 reviews
Enfin satisfait
J’ai acheté ce dac ampli casque pour pouvoir exploiter min recent achat d’un casque moondrop para sur ce même site. Ce dernier sous 08ohms manquait cruellement de volume connecté à mon littledot mk2.
Aujourd’hui, totale satisfaction la puissance 3watts sous 16 ohms est parfaite pour mon casque.
Je découvre le dac et envisage un abonnement pour exploiter ses capacités au delà du mp3 et aac.
Merci à audiophonics pour l’expédition rapide et l’emballage serieux.
This review has been posted for SMSL DL200 DAC ES9039Q2M Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD
The best amp/dac for the price.
I use it when I'm working.
It has an amazing sound. The connections are very good. All the youth problems reported are already corrected. I am very happy with it. Recommend.
Competent product with minor setbacks
SMSL DL200 is a solidly built, pretty good-looking DAC/HPamp with a nice set of features.
The screen isn't big but it is very clear and easy to see from several meters away, and the sound quality is as good as it gets in this price category. I'm using it as a DAC in my system so I cannot say anything regarding to the headphone amplifier. Among the pros, there are a couple of cons, though.
Firstly, it doesn't have signal-sensing auto-on feature, so you have to manually turn it on (and off) every time. I'm hoping this could be fixed with a driver update. Secondly, the USB-C port is VERY sensitive to slightest movement of the unit or cable and leads to the DAC dropping out of sync with the signal source and a very loud, short hissing noise from the speakers, so do not move it around when playing music.
All in all I've been pleased with the product. It isn't perfect but it comes with a very competent set of features and good build quality.
Recommended for the sound quality and connections
It clearly improved the sound quality and the gain of my setup.
I'm using it with a pair of active monitors. First connected by RCA and then using the balanced 6.35mm TRS jacks.
The USB quality is great.
Via Bluetooth is also very good (the DAC seems to detect the best codec for each connection. In may case used Ldac with Android and ACC mainly with iOS. It works at leat up to 10 meters even with walls in between.
It has a huge volume range that allows maximum detail.
The screen, apart from the source and out connections, shows the kHz rate quality and the volume when in use.
It would be great if, when possible, it showed the bit rate of the track.
The built looks good, of quality and solid for the DAC itself and for the remote. But I found a couple of minor issues with the materials: The base of the DAC is not perfectly straight, and the device does not sit well on the table, wobbling a little. A small non-slip feet pad fixed the problem.
It was not possible to fully adjust the Bluetooth antenna, preventing it from maintaining its vertical position. Again, a piece of duct tape did the trick.
I like the integrated energy transformer but it makes the device bulkier.
The remote is solid although for it to work it must positioned directly pointed to the DAC and without any obstacles. The minimum intrusion or side positioning will prevent it from work.
Take into account that it does not include AAA batteries for the remote and you will need them for it to work.
As cable it comes with the energy cable and the USB-C to USB 3.0.
The SMSL DL200 is a high-performance DAC featuring high-quality components such as an ES9039Q2M chip, a USB...
