SMSL DO200 MKII DAC 2x ES9068AS XMOS XU316 Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA
SMSL's DO200 DAC is back in an improved version, the DO200 MKII. As for its big brother, its digital/analog conversion stage is equipped with two ESS9068AS DAC chips, able to offer a transparent, rich and precise sound reproduction. The USB interface is however updated with the excellent XMOS XU-316 chip. The combination of these two components allows the support of high sampling rates, up to PCM 32bit 768kHz, DSD512 as well as the decoding of MQA files. The display of the device has also been modified to offer a better readability.
By buying this product you get 54 loyalty points
Reference : 16859
549,00 €tax incl.
457,50 € tax excl.
SMSL DO200 MKII
DAC 2x ES9068AS XMOS XU-316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
SMSL DO200 MKII DAC ES9068AS XMOS XU-316 Bluetooth 5.0 32bit 768kHz DSD512 MQA
SMSL DO200 DAC ES9068AS XMOS Bluetooth 5.0 32bit 768kHz DSD512 MQA
MQA decoding
MQA (Master Quality Authenticated) is an award-winning British technology that restores the sound of the original recording. The MQA Master file is authenticated by the artists, producers or rights holders. These files are light enough to stream or download.
The DO200 MKII incorporates an MQA decoder to read these files in order to provide the best possible audio quality.
Bluetooth 5.0 - QCC5125
Particularly practical, the DO200 MKII, in addition to its connectivity, is equipped with a Bluetooth 5.0 receiver from Qualcomm. This one supports the classic codecs SBC and AAC, as well as the high quality codecs aptX, aptX-HD and LDAC, allowing to reach a restitution close to that of the CD, in wireless.
A readable and practical screen
The DO200 MKII is equipped with a new, brighter and more readable display, protected by a tempered glass window. It clearly displays all the essential information for a comfortable use of the camera.
Versatile connectivity
The back of DO200 MKII reveals a particularly complete connectic, allowing the DAC to adapt to the great majority of audio systems. On the input side, we find USB-B, I2S via HDMI, AES/EBU, optical, coaxial and of course Bluetooth. On the output side, the DO200 provides single-ended stereo RCA and balanced stereo XLR.
1Multi-function button
2Screen
3IR receiver
4RCA output
5Bluetooth antenna
6Optical input
7Power supply connector
8Balanced XLR output
9AES/EBU input
10I2S via HDMI input
11Coaxial input
12USB-B input
13Power button
Product typeDAC
DAC chip2x ES9068AS
InputsBluetooth 5.0
1x AES/EBU
1x I2S via HDMI
1x Coaxial
1x USB-B
1x Optical Toslink
1x Balanced stereo XLR
THD+N0.00008% (-122dB)
Dynamic rangeXLR : 129dB
RCA : 125dB
SNR128dB
Output impedance< 10Ω
USB transmission modeAsynchronous
Supported sampling ratesUSB, I2S : PCM up to 32bit 768kHz, DSD up to DSD512
Optical, Coaxial, AES/EBU : PCM up to 24bit 192kHz, DSD DoP up to DSD64
Supplt voltage100-240VAC (power cable included)
Consumption5W
Standby consumption< 0.5W
Dimensions / Weight210*40/170mm / 1,2kg
Remote cotnrolYes
Housing materialAluminum
Package1x SMSL DO200 MKII
1x Remote control
1x Antenna
1x USB cable
1x Power cable
InputAES/EBU
InputI2S via HDMI
DAC / ADC ChipES9068AS
Max sampling rateMQA
Max sampling rate768kHz
Max sampling rateDSD512
Remote ControlYes
SMSL's DO200 DAC is back in an improved version, the DO200 MKII. As for its big brother, its digital/analog conversion stage is equipped with...
