By buying this product you get 42 loyalty points
With its DO200 PRO, SMSL breaks new ground and unveils an ultra-high-performance balanced DAC incorporating no less than twelve Cirrus Logic CS43131 DAC chips and an XMOS XU316 USB interface for ultra-high performance. It supports high-resolution streams up to PCM 32bit 768kHz, native DSD up to DSD256, as well as MQA/MQA-CD streams. The DO200 PRO features wireless connectivity thanks to a Qualcomm QCC5125 Bluetooth chip supporting aptX, aptX-HD and LDAC 24bit/96kHz codecs. One of its major assets is its connectivity and compatibility, made possible by an HDMI ARC port, a USB-C input and optical inputs. Regarding the chassis, we're back to SMSL's slim, sober design, with a color screen that displays information on the track being played and makes it easy to navigate through the DAC DO200 PRO's various parameters.
Innovative brand SMSL goes so far as to implement 12 Cirrus Logic CS43131 DAC chips in its DO200 PRO DAC, creating a 12-core driver configuration for high processing power and audio resolution. Digital-to-analog conversion is therefore effortless, even for rich signals. Texas Instrument's OPA1612 AOPs are used to amplify and texture the signal at the DO200 PRO's output.
The DO200 PRO's USB-C input is coupled to a third-generation XMOS XU316 interface, enabling it to support high-resolution PCM 32 bit 768kHz streams, and native DSD up to DSD256 for the most vivid sound reproduction.
The HDMI ARC port on the DO200 PRO lets you retrieve the audio signal from a TV for a slightly more immersive experience, thanks to a combo amplifier and passive speakers, or simply active speakers.
A QCC5125 Bluetooth receiver chip enables this DAC to support high-definition wireless transmission codecs: SBC, AAC, aptX, aptX HD and LDAC 24bit/96kHz. The DO200 PRO can therefore be paired with a smartphone or tablet to enjoy your streaming applications quickly and easily.
The DO200 PRO's USB-C port is compatible with both USB1.1 and USB2.0. To enjoy your console, whether PS5 or Nintendo Switch, simply switch to USB1.1 mode. USB 1.1 supports 24bit/96kHz PCM streams. Once your DAC has been switched to USB1.1 mode, simply restart it for the change to take effect.
MQA x8 and MQA CD files are supported by Toslink optical, SPDIF Coaxial and USB-C inputs for users wishing to enjoy audio files as close as possible to studio recording files.
The DO200 features a "VARIABLE" mode for volume adjustment, as well as a "FIXED" mode for a fixed output level. In addition, an adjustable gain via a switch on the underside of the case allows the output level to be adjusted to 4V or 5V. To complete the package, SMSL has integrated 5 PCM filters to adjust the sound according to your preferences or the type of track being played.
The new SMSL RC-8C remote control allows you to remotely control the DO200 PRO for a smooth user experience and easy navigation through settings and parameters.
1 | Display |
2 | IR receiver |
3 | LED indicator |
4 | Volume control |
5 | Analog RCA stereo output |
6 | XLR balanced stereo analog output |
7 | SPDIF coaxial input |
8 | Toslink optical input |
9 | HDMI ARC |
10 | Bluetooth antenna |
11 | USB-C input |
12 | Power input |
13 | Power switch |
"The DO200 Pro DAC turns in state of the art performance for what is a very good price these days for a balanced DAC. Inclusion of HDMI ARC I am sure is appreciated by many. There are a few minor nits but nothing remotely interfering with fully transparent (to source) operation of the unit. I am happy to recommend the SMSL DO200 Pro."
Product type | DAC |
DAC chip | 12x CS43131 |
USB interface | XMOS XU316 |
Bluetooth chip | Qualcomm QCC5125 |
OPA | OPA1612 |
Inputs | 1x USB-C input 1x HDMI ARC port 1x Toslink optical input 1x Coaxial input Bluetooth |
Outputs | 1x RCA output 1x XLR balanced output |
Supported sample rates | USB-C: PCM 32bit 768kHz, DSD256, MQA/MQA-CD Toslink optical and SPDIF coaxial: 24bit 192kHz, DSD DoP64 |
Bluetooth | 5.1 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX HD, LDAC |
Max. output level | RCA: 2.5Vrms XLR: 5.2Vrms |
THD+N | 0.00006% (-123dB) |
Dynamic range | RCA: 128dB XLR: 134dB |
SNR | RCA: 128dB XLR: 134dB |
USB transmission | Asynchronous |
USB compatibility | Windows 7/8/8.1/10/11 (with driver) MAC OSX10.6 & Linux (without driver) |
Operating modes | VARIABLE: volume control FIXED : fixed output level |
Screen adjustement | Brightness (1 to 8) |
Screen saver | 5-60 seconds |
Power consumption | Operating: < 10W Standby: < 0.5W |
Color | Black |
Dimensions | 189 x 45 x 186mm |
Weight | 1.15Kg |
Package | 1x SMSL DO200 PRO DAC 1x USB-A to USB-C cable 1x Bluetooth antenna 1x IR remote control 1x Mains power cable |
Input | SPDIF |
Input | Bluetooth |
Input | USB |
Input | Optical |
Input | HDMI ARC |
Output | RCA |
Output | XLR |
DAC / ADC Chip | CS43131 |
Max sampling rate | 768kHz |
Max sampling rate | DSD256 |
Max sampling rate | MQA |
Color | Black |
Networking | No |
Remote Control | Yes |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Balázs A.
