SMSL DS200 DAC Headphone Amplifier
New
With the DS200, SMSL presents a compact DAC and headphone amplifier with a retro-futuristic aesthetic. It's equipped with a Cirrus Logic CS43131 DAC chip combined with a 3rd-generation XMOS XU-316 chip, enabling it to support sampling rates up to PCM up to 32bit 768kHz and DSD up to DSD256, with a total harmonic distortion of just 0.00019%. Its coaxial, USB, and optical inputs and Bluetooth 5.1 connectivity make it a flexible device, capable of integrating into a wide range of configurations.
Reference : 20802
129,00 €tax incl.
107,50 € tax excl.
SMSL DS200 DAC Headphone Amplifier CS43131 XMOS XU316 32bit 768kHz DSD526
SMSL DS200 : Front view
SMSL DS200 Overview
SMSL DS200 : Explanatory diagram
1Mode selector
2Power indicator light
3Indicator light for active mode
4Mood light
53.5mm jack headphone output
64.4mm jack headphone output
7Gain selector
8Output selector
9Volume control
10Bluetooth antenna
11Line output
12Coaxial input
13Optical input
14Auxiliary USB-C power supply
15USB-C input
Product typeDAC
Headphone Amplifier
Inputs1x Optical Toslink
1x Coaxial
1x USB-C
Bluetooth
Outputs1x Single-ended 3.5mm jack headphone output
1x Balanced 4.4mm jack headphone output
1x Stereo line output
DAC ChipCS43131
Supported sampling ratesUSB : PCM up to 768kHz / DSD up to DSD256
Optical / Coaxial : PCM up to 192kHz / DSD64 (DoP)
Output level2.0Vrms
Dynamic range127dB
Signal-to-noise ratio127dB
Total harmonic distortion more noise (THD+N)< 0.1W
Bluetooth version5.1
Supported Bluetooth codecSBC
Power supply voltage5V DC
Energy consumptionStandby : < 0.1W
In use : 3W
Weight346g
Dimensions70 x 70 x 113mm
ColorSilver
Package1x SMSL DS200
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rateDSD256
Max sampling rate768kHz
ColorSilver
ClassN/A
Download
With the DS200, SMSL presents a compact DAC and headphone amplifier with a retro-futuristic aesthetic. It's equipped with a Cirrus Logic...
