DAC ES9018Q2C XMOS 32bit 768kHz DSD512
SMSL's M100 MKII, an enhanced version of the M100, is a compact, affordable yet powerful DAC. It integrates quality components to offer a very nice sound reproduction, rich and dynamic, while supporting high resolution files.
M100 MKII
M100
DAC
ESS Sabre 9018Q2C
AKM4452
THD+N
0.0003%
0.0008%
DNR
120dB
114dB
SNR
115dB
120dB
PSE Certification
Yes
No
The SMSL M100 MKII uses a XMOS XCore200 XU208+ controller for its USB interface. This one allows a high quality asynchronous transmission and file support up to 32bit 768kHz PCM, Native DSD up to DSD512 and DoP, especially thanks to the custom Thesycon driver used here. In addition, this XMOS chip supports OTG and can therefore receive digital streams from a compatible smartphone or tablet.
The conversion stage of the SMSL M100 MKII, the true heart of this device, is based on a DAC ESS Sabre ES9018Q2C chip. This chip, widely recognized by audiophiles and music lovers, enables precise and crystal-clear sound reproduction.
The internal design of the M100 MKII consists of two separate and superimposed circuits. This particular design effectively limits interference that could alter the audio signal and thus the sound reproduction.
1 | ON/OFF - Function switch |
2 | LED Indicator (Red = ON / Blue = DSD) |
3 | Screen |
4 | Optical input |
5 | Micro USB input |
6 | Micro USB Auxiliary Power Input |
7 | Stereo RCA output |
8 | Coaxial input |
Product type | DAC |
DAC Chip | ESS Sabre ES9018Q2C |
Inputs | 1x Micro USB 1x Optical Toslink 1x SPDIF Coaxial |
Output | 1x Stereo RCA |
Output level | 2Vrms |
THD+N | 0.0003% |
Dynamic range | 120dB |
SNR | 117dB |
USB transmission mode | Asynchronous |
Compatibility | Windows 7 / 8 / 8.1 / 10 Mac OSX 10.6 et ultérieur Linux |
Supported sampling rates | USB : PCM up to 32bit 768kHz, DSD up to DSD512 Optical / Coaxial : PCM up to 24bit 192kHz |
Power supply | 5VDC via Micro USB |
Consumption | 1.2W |
Standby consumption | < 0.1W |
Dimensions | 55 x 55 x 93mm |
Weight | 258g |
Color | Blue |
Package | 1x SMSL M100 MKII 1x USB-A to Micro USB cable |
Input | SPDIF |
Input | Optical |
Output | RCA |
DAC / ADC Chip | ES9018Q2C |
Max sampling rate | 768kHz |
Max sampling rate | DSD512 |
Color | Blue |
Networking | No |
Remote Control | No |
