SMSL M20 DAC Headphone Amplifier Black
The SMSL M20 DAC headphone amplifier benefits from audiophile components and a most singular form factor. It features no less than 4 CS43131 chips and an XMOS XU316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD256 and MQA.
Reference : 20755
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 16-12-2025.
SMSL M20 DAC Headphone Amplifier 4xCS43131 XMOS XU316 TPA6120A2 32bit 768kHz DSD256 Black
Photo of SMSL M20
The SMSL M20 DAC and headphone amplifier benefits from audiophile components and a most singular form factor. It features no less than 4 CS43131 chips and an XMOS XU316 USB interface, enabling it to support sampling rates up to PCM 32bit 768kHz, DSD256 and MQA. On the headphone amplification side, the TPA6120A2 delivers 2x700mW under 16 ohm and up to 2x40mw under 600 ohm. The SMSL M20 is therefore capable of driving many of the headphones and IEMs available on the market. Connectivity includes a USB-C input (2.0/1.1), a stereo line output on 3.5mm jack and, of course, two headphones outputs: single-ended 3.5mm jack and balanced 4.4mm jack.
SMSL M20 highlights
SMSL M20: A low-noise, high-power device
The SMSL M20 integrates a low-noise power supply that powers various audiophile components, whether for its digital-to-analog conversion stage or its headphones amplification stage. In addition to supporting high-resolution streams thanks to no fewer than 4 CS43131 chips, TPA6120A2 headphone amplifier chips enable it to drive audio headphones or IEMs with impedances ranging from 16 ohms to 600 ohms.
Photo of SMSL M20 TPA6120A2 chips
SMSL M20 output power table
16 ohm700mW
32 ohm700 mW
64 ohm350mW
150 ohm160mW
300 ohm80mW
600 ohm40mW
La compatibilité du SMSL M20
SMSL M20: Extended compatibility
The M20's USB-C input can operate in either USB 2.0 or USB 1.1 mode, providing an optimum level of compatibility with a wide range of devices, from computers and smartphones to video game consoles such as the PS5 and Nintendo Switch.
SMSL M20: A device with singular aesthetics
The SMSL M20's attractive tempered-glass panel reveals all its circuitry. Moreover, its hyper-compact form factor enables it to fit easily into any space.
SMSL M20 aesthetics
SMSL M20 overview
SMSL M20 overview
1Operating mode selection
2Volume +
3Volume -
4USB-C input
5USB-C power port
63.5mm line output jack
7Single-ended 3.5mm headphone output
8Balanced 4.4mm headphone output
Product typeDAC / Headphone amplifier
DAC chip4x CS43131
Headphone amplifier chips2x TPA6120A2
Inputs1x USB-C input
Outputs1x 3.5mm jack output
1x 3.5mm jack single-ended headphone output
1x 4.4mm jack balanced headphone output
Supported sample ratesPCM up to 32bit 768kHz
DSD up to DSD256
Headphone output power700mW @ 16Ω
700mW @ 32Ω
350mW @ 64Ω
160mW @ 150Ω
80mW @ 300Ω
40mW @ 600Ω
Output level3.5mm jack line output: 2.5Vrms
3.5mm jack headphone output: 2.5Vrms
4.4mm jack headphone output: 5Vrms
Output impedanceLine: 22 ohm
Headphones: Near 0 ohm
Dynamic rangeJack 3.5mm: 119dB
Jack 4.4mm: 124dB
SNRJack 3.5mm: 119dB
Jack 4.4mm: 124dB
THD+N0.0001% (-115 dB)
USB compatibilityWindows 7/8/8.1/10/11, Android, iOS, macOS 10.6+, Linux
PS5, Nintendo Switch
PCM filtersx5
Power supply5V 1A via USB-C
Energy consumption< 15 W
Standby: < 0.5 W
Dimensions85 x 22.5 x 85 mm
Weight165g
Package1x SMSL M20
1x USB-A to USB-C cable
1x USB-C to USB-C cable
OutputJack 3.5mm
OutputJack 4.4mm
DAC / ADC ChipCS43131
Max sampling rate768kHz
Max sampling rateDSD256
ClassClass A / AB
The SMSL M20 DAC headphone amplifier benefits from audiophile components and a most singular form factor. It features no less than 4 CS43131 chips...
